Tool Talk Discussion Forum
Wiring Air Compressor - Need help.
Iowa Jim
01-29-2006 06:56:00
Folks:
I have an older air compressor with a Leeson 5 HP motor. Last summer the pressure switch broke and the motor burned up. I purchased a replacement motor yesterday, another Leeson, but am confused as to how to rewire it.
The old motor had six leads and a series of capacitors, the new one has only 4 leads and no capacitor. To top it off, there was no wiring schematic included with the new motor.
I am leaning towards calling my electrician to have him install it for me.
Jim
Tom NJ
01-30-2006 17:57:58
 Re: Wiring Air Compressor - Need help. in reply to Iowa Jim, 01-29-2006 06:56:00
Call Leeson they are very helpful, they will fax/email info.
Iowa Jim
01-30-2006 07:20:52
Well I finally took a longer look at the motor and information and found that the capacitors were internal and that this was the correct motor for an air compressor. Infact it is the same model as the one that gave up the ghost.
I simply wired it as the previous one and away she went.
Thanks for the comments.
Jim
MarkB_MI
01-30-2006 03:40:48
For a five horse air compressor on single phase, you will need a capacitor start motor. It sounds like your old motor was capacitor start/capacitor run, since it had more than one capacitor.
Your new motor is definitely not capacitor start, let alone capacitor start/capacitor run. If it's a split-phase motor, it will not have enough starting torque to operate your compressor. If it's three phase, then you have another problem.
You need to find a 240V, single phase, capacitor start/capacitor run motor. Brand is not important.
XRogerX
01-29-2006 13:19:14
Are you sure you didn't buy a 3 phase motor by mistake?
RickL
01-29-2006 07:43:53
Did your old unuit have magnetic started also didn't it. the new motor are notr like old old units. Get you electrican to do it correct!!!!! Also make sure you don't shut these off before they build pressure up and then cycle off on any compressor of qualtiy usually. If you do then they always have to start uop under head pressure. thats what the bleeding off hiss is when then cycle off. I have a different kickoff switch on mine so I can turn it off head of complete cycle and it will bleed head pressure off. Mine is located adjacwnt to my office behind insulated wall so it can start easier in the winter without have to keep the whole shop warm,thus sometime I turn it off before kickout to talk on the phone or dealing with customer. its seven horse unit tied into two eighty gallon tanks
Greg_Ky
01-29-2006 07:02:44
Jim,
Try the web address below and see if that help's Greg.
www.leeson.com/literature/manuals
Kevin (FL)
02-01-2006 12:41:12
 Re: Wiring Air Compressor - Need help. in reply to Greg_Ky, 01-29-2006 07:02:44
Greg,
Do you happen to know if there's an equivalent website for Century motors? I have an old Curtis air compressor with a 3HP 1750 RPM (184T) Century motor and one of the capacitors' terminals corroded off and now I don't know how to reconnect a new one. The unit has been idle for several years since I use my larger gas-powered compressor for jobs needing air.
Thanks
