Tool Talk Discussion Forum
Using a porta-power???
John e.c.MI
01-28-2006 13:38:48
Local JD dealer let me use their porta-power gear puller to pull the snapping rolls on my corn head. After I pulled number four the porta-power unit acts like it has air in the system or it is maybe low on oil??? The piston either doesn"t want to move, or if it does it acts spongy. Do they take hydraulic oil or jack oil? Any other tips on using these things? There was no manual in the box and nothing readable on the unit.
Joe(TX)
01-30-2006 10:25:44
 Re: Using a porta-power??? in reply to John e.c.MI, 01-28-2006 13:38:48
Check the diconnect on the hose to make sure it has not partialy unscrewed.
Ken in Mich
01-30-2006 04:18:49
I used to use them all the time at work. Some just dont seem to work unless you put the pump in the vertical position with the hose down. It was typical to pump it against the chest. Even with plenty of oil this happens.
JD9295
01-29-2006 19:50:12
Do like TGIN said, go by the JD dealer and find out what it takes. We have a hand unit that uses jack oil and an electric that uses a special hyd. oil. I dont know whats special about it but its definately not jack oil
TGIN
01-29-2006 03:45:41
I agree with the others but I would go back where I got it incase it`s somthing eles and you dont want them thinkin you tore it up .
NC Wayne
01-28-2006 21:18:55
I don't know wether your using one of the hand pumps or the air powere pumps but either way it sounds like it might be low on oil. Refill it using a light weight jack oil. Something else to check also is the oil fill plug, cap, or whatever it has. Some of them have a vent position. If it isn't in the vent position when you use it it'll draw a vacuum and make it act strange.
drw
01-28-2006 17:44:06
check the oil level, should be a plug at the end of the oil reservoir (NOT any of the plugs by the pump piston), should be a little below
full. Open the release valve 1-2 full turns, pump a few times with a full stroke & close valve. Pump out ram at least half way. Put the pump up on a work bench or similar height with the ram on the floor, open valve. air in the ram will bleed back up to the reservoir. You may need to repeat once, twice at most.
bradk
01-28-2006 13:52:47
John, sounds like it's low on oil.Ours calls for jack oil.Every time a different end is put on , a small amount of fluid is lost.Fill it up w/ram retracted and should be good to go.~brad
