Tool Talk Discussion Forum
Water supply for pressure washer Q.
Jay87T
01-27-2006 11:21:50
would feeding water into a pressure washer via gravity work? If I had a tank higher than the pressure washer and let gravity carry the water in the pump would this work? or would there not be enough pressure for the pump? also would it reduce the performance? If the pump needs 2.5gpm would there be enough water flowing?
Jay.
JD9295
01-29-2006 19:55:37
 Re: Water supply for pressure washer Q. in reply to Jay87T, 01-27-2006 11:21:50
The pump will draw a vacuum on the suction line. You will have to have more head pressure (pressure from the height (volume) of the tank) or a good hose. It will work fine as long as these two things are good. If you are going to come out of the bottom of the tank you will have head pressure but i would still use a good hose like goodyear braided hose.
However if you use to small of a hose your pump will cavitate and cause damage to the pistons in the pump
JD9295
01-29-2006 20:12:32
 Re: Water supply for pressure washer Q. in reply to JD9295, 01-29-2006 19:55:37
.433 is your multiplier for head pressure
10ft x .433=4.33psi at your ground level. Then you volume, use a 1 in hose and you wwont starve a 2.5gpm pump
Ranger John
01-28-2006 09:16:03
If you have a soap dispenser that is of the suction type. (that is what I have), If there is not enough clear water supplied, it draws from the soap tank.
baler46
01-27-2006 19:50:53
Hi
Yes this will work fine just make sure you have the hose the right size so you get the proper water flow. It should not make a big differents the height of the tank.Like some one eles said make sure hose does not kink or colsops and you will be fine.To check that you can do like that other person said and check how much you get in a bucket
ebbsspeed
01-27-2006 16:37:03
I've used mine with a hose just stuck in a barrel with a screen over the end of the hose. Just make sure your "suction" hose doesn't collapse and you should be good to go.
Rod(NH)
01-27-2006 12:27:19
Hi Jay,
Sure, that should work. The important thing is that you always have a positive water pressure at the actual inlet to the pump at the maximum pump flow rate. That's to prevent damaging pump cavitation. If your pump is rated at 2.5 gpm, then you need to verify that you'll get at least 2.5 gpm supplied at the height you have your tank above the pump. You can check this easily enough by raising the tank, say in a bucket loader or other means, and letting the open end of a garden hose flow into a bucket. Time the flow and if you get at least 2.5 gpm, then you should be good to go. If you don't, you'll have to find a way to raise the tank higher above the pump until such time as you get a free flow of at least 2.5 gpm out an open hose at the same level as the pump.
third party image Rod
old
01-27-2006 12:20:32
I worked for a guy years ago and we had a tank that held about 500 gallion of water and all we did was hook a hose to the bottom of the tank. Didn't matter if the tank was higher or lower the the preassure washer he had.
Butcher
01-27-2006 12:08:44
I dont know about yours but mine states in the owners manual that it will syphon from a tank.
