Tool Talk Discussion Forum
OT Inversion table
Angle Iron
01-26-2006 09:01:53
Just wondering if anyone has used one and do they work. They claim to reduce back pain by reducing pressure in the spine and so on. I see a lot of new ones on ebay but no used ones. If it works it would be a good tool to have. Thanks. Angle Iron
Angle Iron
01-26-2006 16:11:04
 Re: OT Inversion table in reply to Angle Iron, 01-26-2006 09:01:53
Thanks for the response. Thats sort of what I thought about it being a temp thing. Don"t know if I will try one or not. Thanks again.
IMKCMAC
01-26-2006 15:50:09
I have this one.,got it on HSN or the other one.I have two herniated lumbar discs and try to use it a least once a day.I helps but is not a cure.I noticed that if i use it before i go to bed i do sleep better.I invert for 6-10 mins.Depending on your particular problem it should help.Be careful of the cheapies.E-mail me if you need more info.
Robert in Md
01-26-2006 15:27:05
K Mart has started carrying them. Current price is $99.99. My wifes doctor told her the same thing, they only work while you are inverted.
bo
01-26-2006 13:05:10
Yes and no. If you have a compressed disk then it works...while you're on the table. Once you get off the table the vertebre start to compress again. The relief will tend to be temporary while you inverted.
This is not a long term repair, the greater the problem the less the table will help. Eventually, you'll need medical intervention.
