Tool Talk Discussion Forum
Electric fence chargers
Scott TN
01-25-2006 21:01:40
I have a shed full of what i call the 909 fence boxes. They are quite large and are in a metal housing. Seem to be really good boxes. I was wondering if anyone knew where I could get tips on repairing them and if there was a way to increase there output. Thanks for any help or info.
IHFan11
01-26-2006 17:30:19
 Re: Electric fence chargers in reply to Scott TN, 01-25-2006 21:01:40
I sent one to the co. could not find a fuse!they must have had a good laugh on me, Returned charger with a bill for .07cents. The fuses were in the plug!
JD9295
01-26-2006 18:06:39
 Re: Electric fence chargers in reply to IHFan11, 01-26-2006 17:30:19
Always the last place you look:}
JD9295
01-26-2006 16:58:30
Scott, take it to a tv shop and have them put a capacitor from a tv in it. You might have to find an old tv shop, that guy will know what you want.We had a brahma bull that would walk thru 12 gu barb, so we put up a electric strand 5 ft out and he would smell it and walk thru it. I knew it was working cause i did the dumb@ss check on it, ended up on my knees.
After the tv man got done with the charger and i put a ring and chain in his nose, he was on his knees.
Slowpoke
02-01-2006 01:08:48
 Re: Electric fence chargers in reply to JD9295, 01-26-2006 16:58:30
I'll bet that man never fixed another charger.
jeffcat
01-26-2006 15:36:24
Yea for the home fixit guy that will take it apart to see what makes it tick!!! I used to drive the X nuts cause I would take something brand new apart to take a look. Now I know how to put it back together too! Us older school folks have a lot of skills that are quickly dieing out. From a farm I also fixed our charger a few times and also a couple of the neighbors units. I was the electrical wiz kid on the plot. Try a charger that took a DIRECT hit! A VERY discolored box full of all kinds of CHARCOAL by products! More power to ya! Jeffcat
mlm
01-25-2006 22:34:57
I have repaired a number of them. These are the most common repairs.
clicks too fast- dried out capacitor.
dead -bad scr or diac.
erratic clicks -bad diac or scr
dead and burned 150-180 ohm resistors- shorted diode.
clicks ok but no output-bad output tranformer.may be able to repair this part
I don't see any cheap and easy way to increase the output.
ldj
01-26-2006 05:37:17
 Re: Electric fence chargers in reply to mlm, 01-25-2006 22:34:57
Interesting this came up. I have a small about 3" square by 5 " fence charger from Tractor supply that died about 2 years ago. It is made of plastic and couldn't come apart without cutting it open. I thought, what the heck, it's no good, I'll just cut it open. I found a blown fuse inside. I replaced it and it is still working. What puzzles me is why do they have a replaceable fuse in something that isn't made to take apart.
L.D.
Kelly Campbell
01-26-2006 07:47:30
 Re: Electric fence chargers in reply to ldj, 01-26-2006 05:37:17
So you go buy a new one!
