Tool Talk Discussion Forum
Need to find a good log splitter.
Eli lavengood
01-25-2006 20:26:41
Hello everyone, I am looking to buy a gas powered vertical/horizontal log splitter in the next week or two, I was wondering if anyone has any experience with a model that I could possibly find locally at a lowes or home depot. Mostly wanted to know about reliability and diameter of log it will split.
Thanks, Eli- Conyers, GA.
Dave NE IA
01-29-2006 20:53:38
 Re: Need to find a good log splitter. in reply to Eli lavengood, 01-25-2006 20:26:41
When purchasing don't skimp on the splitting force, burning wood is pretty well paying off well. I purchased in 1977 a horizonal model-2 stage pump, 5 hp. Works pretty good, you can stop it, but I spent many years splitting by hand so have a pretty good idea where to start on the bad ones.
I figure there is never a perfect one without modification. I installed a lift pan with a hydrolic cylinder on it. I then plumbed it with a JD valve so it lifts the pan as fast as a cow swithches her tail.
Actualy the lift pan many times server as a storage area--I leave it horizonal so the kids can pile some on deck, PLUS catch the 1/2's that need another trip through the splitter without bending over and picking it off the ground.
We load most wood with a loader with a tine bucket, dump it into a big trailer. The wood splitter is parked infront of the celler wood chute, split wood goes direct into basement from splitter with out handeling again. Lift pan is horizonal with trailer floor so kids can roll the big chunks onto the lift pan.
Just some ideas to save time and wear and tear on your back. The older you get the less fun it is and sore backs make you smarter. I don't see fuel prices coming down so I will probably never retire from burning wood. Dave NE IA
wh
01-26-2006 11:58:43
i bought a tractor supply 6 hp huskee - 22 ton rated that does great. it is vertical/horz and i would not want any other type. as said below on those "large" pieces it sure is nice to just have to roll them over and stand them up for the first few splits.
John - New York
01-26-2006 09:50:20
I'm pleased with the 34 ton Husky I bought at Tractor Supply. I've used it a couple of years and we split quite a bit of wood, including some real tough stuff.
Tim B from MA
01-26-2006 09:28:18
You said you need to buy a "good log splitter". I'd stay away from what they sell at HD and Lowes. The quality of the log splitter has as much to do with how it is set up as it does the engine HP, pump speed and power, etc.
Personally, I would never own a vertical splitter. Bending over everytime you need to set or adjust a log is no good, and they are not set up to use comfortably when in vertical posistion.
Do a search of this bulleting board for "log splitters" you will see many discussions of the the years that will give you some idea what to look for.
Then search the web to find the splitter. My number one recommendation - get a splitter with the wedge on the piston, not one with the wedge on the end of the splitter (i.e., pushes the log onto the ground). Good luck.
Darin in Nebraska
01-26-2006 11:54:12
 Re: Need to find a good log splitter. in reply to Tim B from MA, 01-26-2006 09:28:18
But when you are splitting oak that measures 43 in dia. and 3 big guys can't lift it, that vertical option is a handy little thing. I would buy one with vertical and horizontal. We have one, its a 28 ton and it splits those just fine.
Tim B from MA
01-26-2006 19:16:43
 Re: Need to find a good log splitter. in reply to Darin in Nebraska, 01-26-2006 11:54:12
Darin,
Those rare occassions are what the wedges and sledges are for - splitting wood is a production job. Look for a machine that is set up for comfort and speed. I have been looking on the internet at vertical rigs - without exception, when they are horizontal they are all too tall, and you are practically standing on one of the wheels. And the pile of split wood you make opposiste where you are standing will be falling all over the other wheel, fender, and engine.
Darin in Nebraska
01-27-2006 07:24:16
 Re: Need to find a good log splitter. in reply to Tim B from MA, 01-26-2006 19:16:43
I would have to agree with the wood falling on the fenders, ours look a little rough. As far as hieght goes for when its horizontal, ours is just about right for us. The wheels are in the way also but then your log splitter would be to heavy in the back and fall over backwards when not left hooked to the truck or tractor. I hope you find one that works for you. Darin
Dennis (VA)
01-26-2006 06:24:31
Brought a 24 or 26 ton one from Harbor Freight last month. Has a 8 hp BS. Works great and steel is much thicker than the Big Box units plus it was priced at $799. Only problem is Harbor takes for ever to ship something but shipping from CA to VA was only $38. Just my thought
Bret4207
01-26-2006 05:03:39
I bought a returned model Troy-bilt at Lowes last fall. Got returned for a leaking fitting. New ones- $1300.00 +/-, mine $750.00. No complaints at all once I got the hang of it. It'll split 30" green elm. Not the fastest thing out there but a lot easier than the maul.
Leland
01-25-2006 21:27:11
The ones sold at big box stores and farm suppy stores are all the same and would last a home owner quite a while that would be your best bet if you need one yesterday .
