Tool Talk Discussion Forum
air compressor pump
mtcase
01-24-2006 21:46:40
I have a twin cylinder air compressor pump that I need parts for but cant find. The pump is a jacuzzi bros. model 321/c. the small high pressure piston pin hole is worn oblong and so is the rod end. The large low pressure piston and rod are in perfect shape.This has been a great compressor for years but a valve stuck open and when I took it apart to fix it I found the other problem. Any help on parts and even diagrams would be great. Thank you. Tim
mtcase
01-26-2006 05:32:14
 Re: air compressor pump in reply to mtcase, 01-24-2006 21:46:40
Thanks Larry for the reply, Ill give him a try. Tim
larry in tn
01-25-2006 05:43:47
You might want to try this fellow;
Ralph Baer
[email protected]
Ralph has helped me many times to get parts for older pumps.
