Tool Talk Discussion Forum
welding table sandblast cabinet
GaryK
01-24-2006 15:17:07
Does anyone have a source of plans to build a good welding table and/or a sandblasting cabinet? I need both, but don't want to pay commercial prices. I have a sandblaster, so maybe could retrofit it to a homemade cabinet. Any ideas would be appreciated.
Dave NE IA
01-29-2006 21:19:49
 Re: welding table sandblast cabinet in reply to GaryK, 01-24-2006 15:17:07
I have six smaller cabnets with different types of abrasive in some. Two were store bought, the others home made. I have no idea what you are going to be using it for but I want a bigger one now and got this idea of using a old pull type combine grain hopper for the main shell. It seems like a cheap way out for something that size. Bottom has a slope and a plywood cover.
However it would not be the first time I was off key. Dave NE IA
Ken in Mich
01-26-2006 17:05:21
For a welding table, call your local steel supplier and ask for "drops", which are left over chunks, or rejected from clients. I asked for,(and got) a 4"X 5" of 5/8" steel plate. Picked up some 2" pipe to weld on for legs, real simple. Later I welded angle iron connecting the legs, laid a piece of plywood in for rod and tool storage.
I wouldn"t go any thinner than 1/2", you want something you can beat on.
chvet73
01-25-2006 11:16:40
Lincoln welding has a table on their website. I built it years ago. If I had it to do over, I would have used a 1/4" top. Otherwise it's a good table.
Glen in TX
01-24-2006 22:46:36
The TIP products are good and I have a TIP blaster but a blast cabinet gun made by Trinco and use a foot pedal valve. I found a larger blast cabinet military surplus and rebuilt it reasonably. So check the surplus places. Just use a 5 gal. shop vac on mine and it works fine. You can build a suction tube from 1/2" electrical conduit and use the cheap clear hardware store hose for suction side. Call Southwest Abrasives in Dallas for gloves and other parts 800-945-6185.
www.tptools.com
www.blast-it-all.com
www.brutmfg.com
www.marcousa.com Some good welding and cutting table plans and ideas in some Lincoln Welding books and in some of the recent farm magazines like Successful Farming and Farm Journal.
www.lincolnelectric.com
Charles (in GA)
01-24-2006 20:07:58
Try this link for bead blast cabinet plans and parts.
Charles
mbptractor
01-24-2006 16:09:15
a friend of mine made a sand blaster cabinet out of a 250 gal fuel oil drum. works great for big items.
mechman
01-24-2006 21:41:56
 Re: welding table sandblast cabinet in reply to mbptractor, 01-24-2006 16:09:15
thats a good idea. i like that.
