Tool Talk Discussion Forum
Stainless Steel?
hogman_2002
01-23-2006 20:32:06
I bought a 400 gallon stainless steel water tank. Or atleast I think it's stainless. It was used buy the military to haul water. It's 7' long and about 3.5' in diameter. It's double walled with a layer of insulation between them. I got a magnet and held it to the tank but it did't stick. So now I'm wondering if it is made of stainless or aluminum. I thought a magnet would stick to stainless steel, hence the name steel. Or are there certain grades of stainless that a magnet won't stick to? I want to use it to haul diesel to the field.
Ken in Mich
01-26-2006 17:32:37
 Re: Stainless Steel? in reply to hogman_2002, 01-23-2006 20:32:06
There is a long list of types of stainless steel, some are magnetic, most are not. You might figure up the weight, the aluminum would be so much lighter. Stainless is real close to regular steel far as weight, about 5 lbs per 1/8" of thickness per sq ft.
Mike in MI
01-24-2006 15:10:38
Hogman,
Wife works a a fabricating shop she says a magnet
will not to all grade of stainless steal.
Mike
Fawteen
01-24-2006 14:45:19
Find a convenient spot, and kiss it with a grinder. If it throws sparks, it's stainless, if not, it's aluminum.
hogman_2002
01-24-2006 06:48:04
There is a tag on the tank that says it was made by Aero Welding. I looked on the internet and found a place from Ohio. They don't have a webiste so I can't get ahold of them. I need to weld up a 12" opening on the top where you fill the tank. I only need a 3" hole to fill it up with diesel. Maybe if I do some more looking I could find a phone # and give them a call. Then I could find out exactly what it's made of.
MarkB_MI
01-24-2006 02:38:52
It's probably stainless, but what difference does it make if it's aluminum? Diesel is much lighter than water, so if it can handle water, fuel should be no problem.
Steve Crum
01-23-2006 21:09:40
Most of the 300 grade stainless steels are not magnetic unless work hardened ie; cuttings, grindings or drill cuttings. 400 grade stainless steels are magnetic due to higher iron content and are heat hardenable. This is what most cutlery and other objects that must hold a reasonable edge are made of. 400 grades are more inclined to corrosion wheras 300 grades are highly corrosion resistant but not heat hardenable. Most likely your tank being a military water tank, it is made of 304 stainless which is most cost effective and widely used in applications such as this, but then again being from the military it could be 316 stainless which is more corrosion resistant and about twice the cost.
Roy Suomi
01-23-2006 20:51:19
304 stainless is not magnetic....
