Tool Talk Discussion Forum
The only EZ out to buy and the last one also
old
01-23-2006 18:47:09
There called Hanson screw ext. Made by Irwin Co. Wilmington Ohio. This type of EZ out will not brake like the cheap ones do and will remove almost any bolt or fitting you need to remove. I have had a set of them for 10 plus years and have never broke on and have never not gotten the bolt or fitting out when useing them. A set of 25 cost me around $60 10 years ago but have been worth it. Any good auto parts store should be able to order them. I got my set from O'reillys auto parts but it did take about a week for them to get them in.
larry in tn
01-24-2006 06:00:08
 Re: The only EZ out to buy and the last one also in reply to old, 01-23-2006 18:47:09
I have a set of Snap-On (EZ-outs) that are the best I've ever used or owned. This set is 20 years old and has never failed to extract my mistakes. They were expensive but have long since paid for themselves.
Rauville
01-24-2006 04:53:15
Leafing through an old manual for a Wisconsin VF4 the other day and had to smile when I came to the overhaul section. The manual shows how to remove the tinwork and then states that the "head screws are easily removable". Wisconsin must have had stock in the EZ-out company the way those old iron head things could snap bolts!
Don c
01-24-2006 03:22:08
I have a few Hanson ext. and they are good, also like the Hanson drill bits, seem to hold there edge a little better.
Davis In SC
01-23-2006 20:54:04
A side note on using easy-outs... Always turn them with a Tap Handle, not a Crescent Wrench... Treat them just like a tap, keep equal force on both ends of the handle...Very few taps are broken by torque, almost all breaking is caused by unequal pressure to one side...
old
01-23-2006 21:18:29
 Re: The only EZ out to buy and the last one also in reply to Davis In SC, 01-23-2006 20:54:04
This type of EZ out can not be used with a tap handle. They have hex heads on them like a bolt and you use a wrench or scoket on them.
Davis In SC
01-24-2006 19:29:41
 Re: The only EZ out to buy and the last one also in reply to old, 01-23-2006 21:18:29
The Hanson ones I get come from J&L Ind Supply... I guess they make them with Square heads for the industrial side, & hex for sale thru Automotive Parts places...
old
01-24-2006 19:53:56
 Re: The only EZ out to buy and the last one also in reply to Davis In SC, 01-24-2006 19:29:41
The ones I have have the hex type heads. They start out with 1/2 inch hex head and go up to 15/16 inch hex head.
alg
01-23-2006 20:14:46
Old, found them on mytoolstore.com.Set of 6 for $15.00.
old
01-23-2006 21:20:24
 Re: The only EZ out to buy and the last one also in reply to alg, 01-23-2006 20:14:46
Thats the small set the set I have has 25 of them. 1/8 to 7/8.
Glen in TX
01-23-2006 19:23:24
The twist type LH EZouts and LH drill bits ? Glad yours work good. I got a set of Hanson brand too and broke half of mine in less than 3 years and wasn't too impressed with them. I have been happy with the Lawson brand I bought to replace them with but OUCH they cost more too. Also been happy with LH drill bits from MSC or McMaster Carr.
old
01-23-2006 19:27:57
 Re: The only EZ out to buy and the last one also in reply to Glen in TX, 01-23-2006 19:23:24
It may also depend on who made them or should I say what brand they are. This set I have is about 10 plus years old and of course like most things the older they are the better made
Glen in TX
01-25-2006 10:49:13
 Re: The only EZ out to buy and the last one also in reply to old, 01-23-2006 19:27:57
Mine are Hanson. The small spiral set with drills. EZouts I have sound different than yours. The EZouts are okay if careful but I've replaced most all of the LH drills with Lawson brand now. Hanson drill bits sold around here have never been very good for my use.
old
01-25-2006 11:06:34
 Re: The only EZ out to buy and the last one also in reply to Glen in TX, 01-25-2006 10:49:13
Hanson is the type/style not the brand name that they where made under. The brand I have is Irwin which is an industrial brand not jsut a by off the self type. They didn't camoe with drill bits just the EZ outs. Each one is only about 1 inch long with the EZ out part being half that long and the hex head the other half. To get this set I had to special order them and took them a week or more just to get them in. I could have got the cheaper set but I went the high dolor way and got the good ones
Davis In SC
01-23-2006 19:01:58
I buy the Hanson ones, they are good. I always like the Cleveland ones best, but can no longer find them. Worst ones are the cheap import ones, with the fast spiral .. Years ago, a mechanic at a place I worked, bought several sets of the cheap ones, to keep in his box. I ran the machine shop, & it seemed every few days, I would have to EDM a broken one out. Finally, I asked him how much he had paid for them, & got them to sell me the ones he had left... I promptly threw them in the dumpster, & made the plant manager reimburse me for them... Best money that Co. ever spent, LOL
