Tool Talk Discussion Forum
OT: tankless water heaters.
midwest redneck
01-23-2006 02:28:26
I know this has been brought up before. But I think I am going to buy a tankless water heater with my tax return money. My current tank is a 50 gallon power vent, 6 years old now. I dont want to come home to the thing leaking or gushing water. Questions: How much does a tankless heater cost? Are they power vent? (I have a PVC vent now to the outside for my power vent) Are they as good as a regular water heater. What are the warrantys like? Could I install this myself, I put in two regular water heaters several years ago.
johnlobb
01-23-2006 16:04:06
 Re: OT: tankless water heaters. in reply to midwest rednecker, 01-23-2006 02:28:26
I used to be the heating manager at a large plumbing wholesaler in Detroit 12 yrs ago. I had a Detroit cop want one of these.(gas). He installed it for he and his wife. Came in and complained that his water only got lukewarm. I asked him what type of showerhead he had and he said "Speakman". That is a very large showerhead that salmon could swim upstream in. (many gallons per hour) I also had him check the temp of his incoming water and it was 36 degrees. I also had him clock his gas meter, and it turned out he had installed as a gas valve an old lubricated plug cock that reduced the flow of gas a lot. He needed a full flow ball valve. After fixing all these things, (new lo flow shower head, new ball valve) he realized they could not do like the typical American couple; get home from work, turn the clothes and dish washers on, she draw a tub, and he take a shower all at once. You can usually do ONE thing at a time. There are a lot of these water heaters in use in Europe, but people there don"t seem to be as impatient as us Americans. For a tank type heater, try to find one made in Canada called either a GSW or John Wood brand. They make them differant than here and they last longer. John L.
Charles (in GA)
01-23-2006 15:25:18
Lady down the road installed one about two years ago. Gas. She saw a large drop in LP consumption, but her old tank unit was a horribly inefficient old 40 gal that was installed in a unfinished, uninsulated pantry room off the kitchen of a 100 year old farmhouse. She has since insulated and finished the pantry and it is the warmest room in the house now.
Anyhow, the new tankless unit suddenly started leaking last year. The company tried to tell her it had been mis-installed as the gas vent went thru the roof like the old one. They said it had to have a horizontal vent, no other way allowed. Problem was a pinhole in the outside radius of a tube in the heat exchanger, no relation to water condensation, corrosion, etc from the vent pipe. They finally relented and shipped her a new one and sent a authorized representative (plumber) to install it. He installed a new thru the wall stainless vent and this was a larger unit than the old one. She lives by herself and likes it. The more water you use, the higher the fire. You can turn on a faucet, and hear it start up, open the faucet more, hear it ramp up, go turn on the shower, it picks up even more.
Whole house electric units require huge feeds to run them.
Do some google searches for tankless water heater and see what you get, lots of info.
Charles
Midwest redneck
01-23-2006 13:29:56
Thanks guys, I guess the tankless heaters are electric huh. No gas to put up with. I would like the fact that it is electric, I am guessin that it is 220VAC. Lets see, probably draws 20 amps when running, so.....4400 watts = 38 cents per hour to run, the heater would run for 1 hour per day or $12/month to run, maybe as high as $20.
jhill
01-23-2006 15:47:18
 Re: OT: tankless water heaters. in reply to Midwest redneck, 01-23-2006 13:29:56
I installed an electric tankless heater for some people this wear. It took 2 220 volt 40 amp circuits to run it. I had to run no 6 wire. There was a larger on one that required 3 circuits. Used alot of power when running but there was unlimited hot water. Its in a vacation home so I don't know how much it cost to run.
bo
01-23-2006 13:35:34
No...they can also be gas. No, not 20 amp,,a small one just for the sink like I have is 40 amps. The bigger ones for a whole house could run as high as 100 amps. You need to study up on this a whole lot more.
Steve Crum
01-23-2006 08:54:34
Good post! I'm looking at leasing one of the Sepco 80 gallon stone lined tanks for the house and family of 4. (2 teenagers that heaven forbid, smell anything like a living organism). Right now I'm using a 40 gallon LP gas hot water heater, along with the kitchen stove, propane is costing about $180 a month. I would be leasing this from the rural electic coop and it would be on time of day. One sticking point for me is that no matter how you calculate the cost, (energy cost, membership cost, cost of distribution etc) it still comes out to about $.18 a KWH for power here.
I've argued with the power company who claims I cannot include all their parasitic costs in my cost for electric here, But isn't my cost based on KWH used divided by amount the check is written for?
David - OR
01-23-2006 07:13:11
Almost all of the energy used by a water heater goes to heat the water consumed by the household. The standby losses are much less than you may have been lead to believe by the sellers of tankless units, and are nearly negligible if the water heater is inside a space you have to heat anyway.
A 50 gallon tank of 125 degree water insulated to R11 which is kept in a relatively unheated space averaging 40 degrees (F) loses about $4.00 worth of energy per month to the surrounding environment. It is a basic heat flow problem and not difficult to calculate.
A gas water heater loses more than an electric water heater, since it has a center flue which can allow some heat to be lost to the center and then up the stack even with the burner not running. This can be combatted in high efficiency models, but I would still not expect the loss to be more than another $2.00 per month.
If the water heater is in a closet or your conditioned basement, then the standby heat loss is near zero in the winter time -- only that $2.00 per month going up the stack. The rest of the "waste" heat helps you heat your house and reduces the load on your furnace.
A tankless model with sufficient capacity for your household might cost $1200 and have a service life of 12 years. Your "savings" will be -$38.00 per year. (That is a net loss of $38.00 per year). And this does not consider the time value of money, which almost doubles the negative savings.
Tankless models make sense if you have space limitations, have a very intermittant demand, or need to winterize frequently. A shop sink comes to mind, as these can use smaller and less expensive models, little water is actually used, so the standby is a bigger relative factor, and you may not heat the shop in the coldest weather and have problems with freezing of an ordinary water heater.
But for a whole house situation, I certainly would not spend my tax return check on such a "savings".
Gary Schafer
01-23-2006 08:39:28
 Re: OT: tankless water heaters. in reply to David - OR, 01-23-2006 07:13:11
Your $4.00 / month in lost heat is a little low. How did you come up with that number?
I have actually measured my electric water heaters and found that it cost around $30.00 per month to operate them even when no water is being used. I attached a running time meter to them to find the number of hours of actual operation in a month. Multiplied by the amount of power drawn. At 8 cents per kilowatt hour it worked out to near $30.00 per month to operate each one.
Our water use is not high. Only 2 in family. When gone for a few weeks the cost to keep the water hot did not change by much, only a few dollars.
At the time I did the measurements I had a house with two 40 gallon water heaters. One in the garage and one inside the house in air conditioned space. House located in South Florida.
Regards
Gary
David - OR
01-24-2006 18:26:16
 Re: OT: tankless water heaters. in reply to Gary Schafer, 01-23-2006 08:39:28
A 50 gallon electric water heater tank is a cylinder about 16 inches in diameter and 5 feet tall. The cylinder has a surface area of 60 * 16 * 3.14 + 2 * 16 * 16 * 3.14 / 4 * 2 or around 3300 square inches.
Call it 23 square feet.
If the water temperature is 125 degrees and the ambient is 40 degrees and the insulation is R11 then the heat loss is
23 * (125 - 40) / 11 or 178 BTU per hour
there are 24 * 30 hours in a month, so the heat loss is 178 * 24 * 30 = 128000 BTU per month
There are 3413 BTU per kilowatt hour, so we use 37.5 KWH to replace the lost heat. (Electric heaters are 100 percent efficient).
At 0.08 dollars per kilowatt hour, we have $3.00 per month. That's where I got the number I quoted.
Several of these assumptions may be optimistic. Assume the water heater is miserable cheap one insulated only to R4, and the water temperature is a toasty 140 degrees. Under these conditions we use 3 times as much energy to maintain the temperature, but that is still only $9.00 per month, or $18.00 per month per two water heaters.
(I have neglected conductive loss to the piping, but I don't think this amounts to much).
For a situation in Florida, the average ambient would be more like 60 degrees, which would make the heat loss more like $16.00 per month.
I cannot explain the $30.00 per month that you measured. Maybe you have a leaky faucet? Or maybe there was something wrong with how you did the measurement?
My own anecdotal experiences come from shops and houses sitting idle with the water heater left on. The only thing spinning the electric meter is the standby loss. At the end of the month it is easy enough to read the electric bill and observe the cost of the hot water sitting there unused. The figures I have seen are more consistent with the $3.00 to $8.00 range.
Jay (ND)
01-23-2006 08:25:27
Great informative post. While I have no experience with these water heaters, the plumbing contractors I know share your opinion that they shouldn't be used for a whole house application - well, unless you're a bachelor maybe. Just can't supply enough hot water to multiple locations all at once.
Dennis (VA)
01-23-2006 07:12:56
Installed a whole house electric unit, Bosch, a little over a year ago when we built the house. Very pleased with unit and it does save a ton of money on electricity. With continually rising energy prices can only get better. Takes some serious electrical work to install. Brought off web from Link which was much cheaper than Home D or Lowes. Agree though a heater six years old should have at least another six years left.
BobMo
01-23-2006 07:04:51
Why don't you go down to Lowes or Home Depot and get the information your looking for then you'll have it right..... ..... .Not based on the sales person but on the provided (free)literature.
steve in in
01-23-2006 05:18:11
Where are you at? I'll take your old one. 6 years old? Mine was 15 years old when I moved into my house nearly 8 years ago. Hasn't leaked yet.
Midwest redneck
01-23-2006 13:21:10
 Re: OT: tankless water heaters. in reply to steve in in, 01-23-2006 05:18:11
I am in michigan, 100 miles north of Ohio. off of I-75. I will post when I get a new water heater.
bo
01-23-2006 03:22:25
Good for spot heating water...at the sink for example. Have to run in some major power line for the electric ones. The size of the power depends on the size of the unit.
There are gas ones available also, most need an outside vent and don't know if they are power vented.
The bigger the unit, the greater the cost, figure at least 3x the cost of a tank heater.
I put a small one in for the sink in the barn, 8 guage, 220 power line and it works great. Hot water in about 5 seconds. Bought it on Ebay for 170 and with the power line, about 250 all. For that kind of money, I could have installed a tank but didn't want to store hot water all the time.
Whole house heater...you won't get away for less than 1k....
Will still take time to get hot water to the shower or wherever depending on the length of water line.
They do work well. They are expensive, they do last longer, they do gunk up over time depending on the minerals in your water.
Net analysis, good when you need spot hot water, but the tank heaters are cheaper and equally as reliable, maybe better than the tankless ones for whole house hot water.
pgo12
01-23-2006 03:29:27
 Re: OT: tankless water heaters. in reply to bo, 01-23-2006 03:22:25
depending on the model, and fixtures running off the heater, you may need more than one. some gas heaters require a bigger gas line to run efficiantly. depending how long you plan on living there, will depend on the heater[s] you invest in. they are not cheap. pg
504
01-23-2006 20:30:46
 Re: OT: tankless water heaters. in reply to pgo12, 01-23-2006 03:29:27
I put in a Bosch when we built the house 3yr ago. It has a variable water valve,should have a variable flame instead. But for the difference in money I would stay with the Bosch.($1500.
00)
