Tool Talk Discussion Forum
P.S.
OK-AL
01-22-2006 19:49:04
Just had a thought. The smallest flux core wire diameter that i've every used is .045". If you're trying to push .045" wire through a .035" tip, then it's no surprise that it's sticking.
Also, the liner in the gun cable may need to be changed to a larger diameter.
Double-check your wire size.
OK-AL
Stan in Oly, WA
01-22-2006 21:24:24
 Re: P.S. in reply to OK-AL, 01-22-2006 19:49:04
Good thinking. I thought I could prove you were right by looking through Lincoln's catalog of all the FC wire they sell (I guess it wouldn't actually prove it since someone else could sell a size wire that Lincoln didn't, but I'd consider it strong evidence.) Anyway, Lincoln sells just one type of FC wire in .035; everything else is .045 and up. But the one they sell is Innershield NR-211-MP, one of their most popular general purpose FC wires, so there's bound to be plenty of it around. That's not to say that Brian shouldn't check the match-up of the tip size to the wire size...only that it turns out not to be one of those great "Aha, problem solved," type situations.
Stan
