Tool Talk Discussion Forum
OT-12 volt coolers
Ron 1456
01-22-2006 16:38:57
I have been thinking about getting a 12 volt cooler to use in my truck. The Igloo is a bit more expensive than the Coleman but they are the only 2 I have looked at so far. Anyone have any thoughts on which one would be the best one to buy? Thanks
BamaScot
02-03-2006 02:18:30
 Re: OT-12 volt coolers in reply to Ron 1456, 01-22-2006 16:38:57
Get the Igloo, you can get parts easier at truck stops and Wallyworld.
Chris(WA)
01-22-2006 21:57:30
I have one in my service truck to keep my lunch and pop cool. They do a fair job if the food/pop is cold when you put it in. Stays cold as long as the power is on. They draw a lot of power so you do not want to leave it on all the time as it will pull a battery down over night or a weekend. Have not tried the heating feature other than to see if it worked.
Lloyd Llama
01-23-2006 12:45:55
 Re: OT-12 volt coolers in reply to Chris(WA), 01-22-2006 21:57:30
Have 2 of them. As other poster indicates, they draw several amps and will run battery down fairly fast, if vehicle not running. They are fairly good at refrigeration, we use one in our pop-up camper. Run it off the 12volt supply on board. Works fairly well except on extremely hot days. Had great success keeping soda pop and snacks cool when traveling. WARNING - Heat function works too - Wife hooked one up backwards, and had canned sodas blowing up, and leaking all over the cabinet! (She never listens to me when I try to explain things to her like that!)
buickanddeere
01-22-2006 17:23:02
Good idea but they don't move enough btu's to be worth while. In a semi truck bunk I would use a 120V bar fridge and a 12V to 120V invertor. Mine gets used with a block of ice and the fan used to circulate the cool air inside. I even isloated the power to the semi-conductor cooler do-hicky. The external fan has also been removed from the shaft for quieter and lower current operation.
