Tool Talk Discussion Forum
What is a Flapper valve???compressor manifold Q
tino
01-22-2006 14:40:47
I am trying to find my darn check valve in my compressor and am having no luck at all. From my compressor schematic I am showing the check valve to be near the flapper valve. However, there is nothing there.
Does any one know what the flapper valve is for? I have always thought of the check valve to be an entire unit it on its own. Is the flapper going to be part of the check valve system in this case? I have pictures too if you wanna see. I am attempting to fix my compressor but am having some bad luck. I have a post a few comments below.
If I can find my stinkin check valve I think I will be in a good position to fix my pos.
thanks
Adam2
01-23-2006 09:06:22
 Re: What is a Flapper valve???compressor manifold in reply to tino, 01-22-2006 14:40:47
Thank you for listing the "long" model number 919.152930, off of the machine's data plate.
The first three digits are an OEM code.
In your case, OEM vendor 919 is indeed DeVilbiss.
OEMs often carry parts and manuals, long past the time Sears Parts Direct does.
tino
01-23-2006 10:06:07
 Re: What is a Flapper valve???compressor manifold in reply to Adam2, 01-23-2006 09:06:22
Hey guys, thanks again for the replies. I will check with De Vilbiss to see if they can give me any additonal info about the check valve.
So do you guys think what I have described as the flapper valve would actually be working as the check valve? The flapper just kind of "flaps" against a circular bushing type push in fitting. I would love to not have to buy a new compressor and just fix this bad boy.
Hobo,NC
01-23-2006 05:06:54
I just hauled a craftsman compressor tank home from the dump. Compressor izz gone but the tank izz in good condition. I charged it up with air and the check valve in the top of the tank izz bad and I bet that�s what got the compressor. Bo has gave you a good reply. I have also installed a flapper style check valve in the line to the tank. A flapper check valve has a flapper instead of a spring loaded devise to check off the pressure in the tank. The flapper valve will be mounted horizontal and a check valve kin be mounted in enny position as long and the check valve izz installed to allow presser to inter the tank and check off the tank pressure. The checker will be between the pump outlet and the tank and most will be screwed into the inlet side of the tank
Slowpoke
01-22-2006 16:35:25
What happend that you are looking for the check valve? I think the check valve could be nothing more than a ball bearing with a spring pushing it toward the compressor. Maybe the parts list/picture is incorrect. Maybe it's next to the head. Maybe you could show the parts diagram. Maybe you could give the model # so we can see the Sears site diagram. Maybe there's no hope anyway.
bo
01-22-2006 14:43:54
dunno which you have or the set up but most checkvalves are mounted in the top of the tank with a tube going to the piston outlet. Check valves are generic,,,that is, all they are are one way valves..they let in the air and don't let it back into the piston area. That's all they do. Follow the movement of the air to the tank and you'll find it. Screws in.
tino
01-22-2006 15:38:49
 Re: What is a Flapper valve???compressor manifold in reply to bo, 01-22-2006 14:43:54
Bo,
Good points. HOwever, I know what a check valve is and agree with what you have said, I just cant figure out what happened to mine. Or for that matter where it should go.
I have a 2 cylinder, 33 gallon craftsman. So I have 2 air tubes from the heads to the manifold which merge in the manifold and are forced through the flapper valve. I think the check valve should be in the cylinderical space before the flapper. That is my best guess, and there are no threads there so a valve would have to be pushed in, which doesnt make sense.
bo
01-22-2006 16:38:15
 Re: What is a Flapper valve???compressor manifold in reply to tino, 01-22-2006 15:38:49
If it's a Sears, it's got a model number and it's not that 919.....number you posted. Get the real number and post it. I have yet to fail finding a schematic on the Sears parts lists.
tino
01-22-2006 18:50:30
 Re: What is a Flapper valve???compressor manifold in reply to bo, 01-22-2006 16:38:15
Hey thanks for the reply, there was a typo on the previous post. Thee part number for my compressor is actually: 919.152930
I found the diagram online, exactly like the one I have here from sears except more clear.
I am still wondering what a flapper valve....
Slowpoke
01-23-2006 23:52:30
 Re: What is a Flapper valve???compressor manifold in reply to tino, 01-22-2006 18:50:30
Grainger has in-line and in-tank check valves. 1/4", 3/8", 1/2" pipe thread, & tubing style. $7 and up. They sell to business, but if you don't have one, you can go in and look at the counter catalogs anyway. It would be a good idea to take the old valve with you.
bo
01-22-2006 19:16:32
RESTRICTOR, CHECK VALVE CAC-1391 #36 ----here's your check valve. They generally go bad and will bleed out the tank in a short time. A day is not unreasonable. I've replaced two of them in two different compressors. Why your's stop at 60 lbs might be a different story. The flapper valve may or may not be part of the problem. It too, is probably a one way valve.
tino
01-22-2006 19:37:48
 Re: What is a Flapper valve???compressor manifold in reply to bo, 01-22-2006 19:16:32
BTW Bo,
The flapper valve is a very thin piece of aluminum(.050) that has a shape like the end of a popsicle stick. 2 small bolts,hold one end down while the rounded side kind of Hides a cylindrical space that is actually part of the union of the 2 cylinders air flow. That cylinderical space has a kind of plasticl ring in it but the space it self is not a one way valve. I can easy run a piece of rope or string throught the union and out of the flapper with not resistance. Anyway. Let me know what you think guys.
tino
01-22-2006 19:31:15
Yes I see that, I have been searching for it in my compressor for the last couple of days. It seems to be missing and I can not figure if not being able to ID this valve is contributing to my problem. I would like to ID this check valve in my system however I have had no luck finding it. As I mentioned before, I can not even order this part and figure out where it should be since sears no longer has it available. These are the problems I am having.
The compressor itself had been running fine for the past 5years. This is the first problem I have had and it is very annoying.
Sorry for not being more clear before with this post, thanks for the input.
bo
01-22-2006 19:38:08
 Re: What is a Flapper valve???compressor manifold in reply to tino, 01-22-2006 19:31:15
Ok...Sears doesn't carry it. Now you have to locate who manufactured this beast. Might be Devilbiss...once you find out who, you'll find the part. Or...contact a compressor repair facility, they'll fix you up. Frankly, I'm surprised that it is not available.
bo
01-22-2006 19:33:17
It's there. It sits in the lower manifold #26. I suppose you have to take the whole unit off the tank to get at it.
