Tool Talk Discussion Forum
Hydraulic pressure gauge kit
hogman_2002
01-22-2006 13:34:28
I'm looking for a set of gauges to test hydraulic pressures. I need one soon to test pressures on a hydrostat. It needs to go from 0-10,000 psi. I've asked at a few local parts stores and they can get a gauge, but they can't get a hydraulic hose capable of holding 10,000 psi. I was hoping to get a kit, that way I would have to mix and match fittings and sizes.
Bob
01-22-2006 20:02:36
 Re: Hydraulic pressure gauge kit in reply to hogman_2002, 01-22-2006 13:34:28
http://www.mcmaster.com/ has about any gauge you would need.
Or, OTC, see catalog at link below, page 291, 292, and 297.
hogman_2002
01-22-2006 18:11:22
I went to the local JD dealer to begin with. They acted like they don't have nor sell a kit. I've also noticed the Tech manual I'm using gives an address to write to to get a set of gauges. Since the manual was made in 1974, I doubt the address would be accurated.
Tom in Central Pa.
01-22-2006 16:06:19
Many years ago I bought a complete test kit through my John Deere dealer. A good assortment of gauges, hoses, adapters and fittings. Worth the money. See the service manager/ shop forman. Ask to see the Service-gard catalog.
drw
01-22-2006 16:04:57
Call a few hose companies, you should be able to find one that can make one up. 10K is a fairly common application, usually with 1/4" or 3/8" NPT threads. They may go into a discourse of the safety ratios (5000 working, burst of minimum 3-4x that). Where I work we only SELL 10,000 PSI working/20K burst (lawyers & liabilites issues, stay away!), but in the shop we often TEST with the lower rated ones to 10K for short durations.
Lubrication (grease guns) generally are 7000 PSI max. working.
Paul Janke
01-22-2006 15:51:37
I don't know if this will help, but I think hoses for grease guns are rated for 10,000 PSI. They are 1/8 inch pipe threads.
