Tool Talk Discussion Forum
drill press bits
rodgernbama
01-22-2006 12:25:35
I am thinking about buying a bench top drill press. What type bits do you use for metal work? Also how many speeds do you need? It will be used for around the home use and occasional metal fabrication.
Leroy
01-22-2006 17:46:40
 Re: drill press bits in reply to rodgernbama, 01-22-2006 12:25:35
Speed is a lot more important than power, I have a heavy duty (don't remember the power) but it is geared way to fast for any bit over 1/2" in the slowest speed and I never use anything except the slowest of the I think 9 speeds. Before I bought it I boughr a cheap bench top ant that thing ran so fast even in the slowest speed I could not even use a 1/8" drill bit (The smaller the bit the faster it can run), for that small of a bit it needed the speed reduced to 1/4 of the lowest speed and with that runnaway fast speed it did not have enough power to run it without doing any drilling so it went back. The drill I like to use on the bigger size 9/16" and up is my old hand cranked post drill and that runs slow enough you can count the turns of the bit. Running the bits at over speed is what takes the power, get it slowed down and even the smallest motor will have enough power
MikeCatthemuseum
01-22-2006 17:35:43
I'll second the suggestion of more power. Get the biggest motor you can, especially if you are going to be boring big holes. Most belt drive cheapo drill presses won't pull a 3/4" bit very well, and that even goes for the big 1 1/2hp 20" I just got from Wilton. Don't buy one of those either. It is identical to the same size press at HF, costs almost three times as much and is even worse as far as quality goes. Buy the cheapo HF press. It is the same one sold by Crafstman, Wilton, Grizzly, Jet, etc... Just different paint jobs.
Drill presses are a lot like air compressors as far as ratings are concerned. The manufacturers can pretty much put anything they want on there for capacity. They usually rate the drill press at the largest size bit that will go in the chuck they supply with it. That doesn't mean the press will actually pull that bit in most materials short of balsa wood or styrofoam.
Another thing to be aware of is the speed range of the press. For big holes in steel, low rpms are a must. High speed and hp rules for aluminum. A good rule of thumb for drilling in steel is 500rpm for a 1/2" drill bit (60-70sfpm). Conversely 1000rpm for a 1/4" bit and 250 for a 1" bit. This will keep you from blueing the lips due to overspeed or wringing off a bit at too low a speed. These speeds should be quadrupled for aluminum (around 300sfpm). As you see, a 12spd 1hp press with a speed range of 375-2500 is good for 5/8-1/8" holes in steel and pretty much useless in aluminum as it is not fast enough for reasonable sized bits and doesn't have the power to pull a large bit at the required high speeds. My cheapo chinese special is a benchtop 16spd, 3/4hp with a range from 340-4290rpm. It is good enough for poking holes. I use a mill for precise work.
Buy good drill bits. An index set of good ones may run you $100, but as long as they are in your shop and not exposed to a bunch of monkeys who don't care whether they get ruined, they will last for dozens of years. Buy a real Jacob's chuck so you don't ruin the bits due to a slipping chuck. Chinese chucks are awful and will burr up your bits in short order. Get a vise and use it so you don't break your bits when they break though the work and beat the part all over the column.
Keep an eye on Ebay and try to pick up Morse taper drill bits in the larger sizes you want. You can get these for a couple of bucks apiece or less. A drill chuck just can't hold on very well when the bits get bigger and you can get bits larger than your chuck will hold. You should get a MT wedge in the box with the machine to drive them and/or your chuck out of the spindle. You may need an adapter to reduce the taper, which you can also pick up on Ebay for nearly nothing.
One last thing... make SURE to clamp the table to the column after raising or lowering it with the handle. The racks on these are so soft and crappy that they will bow out and break if left with the clamp loose. Ask me how I know.
old
01-22-2006 13:15:39
Weather you got a bench top or stand up go with the highest HP on the motor that you can. I had one of those bench top type with a 1/3HP motor and it was a joke for any thing over 1/2 inch. Also bits over 1/2 inch cost you big bucks for any thing but the cheap one and they will still cost you a lot. I have a set of bits from harbor fright that go from 9/16-1 inch and they where the cheap ones. Cost about $50 when I got them. I get by with them but thats about all. A good 1 inch bit can cost more then $100 just for one bit by the way.
720Deere
01-23-2006 16:05:15
 Re: drill press bits in reply to old, 01-22-2006 13:15:39
I have a set of the HF 9/16" to 1" Silver & Deming bits. They were $20 on sale and have been the best investment that I ever made on drill bits. Slow speed (200 to 350) rpm and cutting fluid makes them cut like crazy and last seemingly forever. I know the 5/8" bit has poked close to 100 holes and is still going strong without being sharpened. It's not always what you have but rather how you use it.
Midwest redneck
01-22-2006 13:30:58
Get a 1/2 horsepw. minimum, try to to get a 3/4HP drill press. As far as drill bits, get bits that are HSS. HSS stands for high speed steel, which is heat treated tool steel, TiN coated too, which is Titanium nitride which acts as a wear resistance and allows longer times between sharpenings.
