Hi, Brian What a great sounding portable setup! I wish I had one just like it. I bought a 200 amp aircraft generator a couple of weeks ago on eBay, sold as a 200 amp welder. I need to find a 10-12 horse engine to run it, but I'm not in a hurry. There are a lot more small engines around than there are aircraft generators, so I expect to not have to pay much for that. Did you figure out why your flux core wire was sticking to the contact tips with your wire feed welder? I'd be interested to find out. I've never welded with straight flux core. The machines in the shop where I weld are set up with solid steel wire, solid silicon-bronze wire, and dual shield wire, all with shielding gas. Dual shield wire is flux core that is meant to be run with shielding gas. Nobody has been able to tell me how it differs from standard flux core, or how flux core would work if you ran it with shielding gas, or if there's any problem with that. So many questions, so little time. Stan
