Tool Talk Discussion Forum
alternator tester for work bench
North M
01-20-2006 13:09:40
I have some used generators and alternators lying around the shop and would like test them to see if they any good. Does any one have a shopbuilt tester they have used and offer some advice on building one. I would use a small electric moter to turn the alternator that is strapped down on a board but do I need anything else like a battery to power the alternator. Thanks
Chester
01-23-2006 18:56:52
 Re: alternator tester for work bench in reply to North M, 01-20-2006 13:09:40
Take a look here:
Link
jeffcat
01-20-2006 22:38:39
I would go with Ray's advice. Local shop can just run them through in no time. Generators you can test with a battery if you hook it up right. It will run slowly and with out too much power. Hot to the ARM or BAT terminal. Ground clamp to the case. Touch out the FLD to the case for just a quick test. I did this the last time about fifteen years ago. Anyone who knows any different; please jump in. Alternators are WAY to dangerous. Melt screw drivers, let smoke out of wires, blow holes in metal bench tops, you get the drift. My $.o2 Jeffcat
J. Schwiebert
01-20-2006 18:30:33
Also remember AMPS times volts equal watts and 746 watts equal one horsepower so if you are going to test anything over say the 30-35 amp size you will need to have at lewast a horse motor. You will need a very good Ohmmeter to test all the components.
RayP(MI)
01-20-2006 17:47:41
A voltmeter, ammeter, and a hand full of bulbs (I use sealed beam headlights - brights, with low beam filament burned out) to create a load for the alternator. Be aware that a hundred amp alternator putting out full power takes a pretty large electric motor to turn it over! If you have just a few, you could probably get a local alternator shop to test them out for you easier than doing it yourself.
old
01-20-2006 17:37:17
Well you would need some way of getting power to the field of the alternator. Some sorce of 12 volts and also some place for the charge current to go so it wouldn't burn out the alternator. I.E. Some sort of load that wouldn't pull to much. An open circiut alternator can put out up to and maybe over 90 volts with out a load
