Tool Talk Discussion Forum
1 5/16 vs 33mm
Rick from Paso
01-19-2006 18:13:37
I have a dumb question, My Freightliner FL70 wheel nuts use M20 flange nuts requiring a 33mm socket. Do you think I could get by with a 1 5/16" socket? Thanks for your help!
Rick from Paso
01-19-2006 19:39:15
 Re: 1 5/16 vs 33mm in reply to Rick from Paso, 01-19-2006 18:13:37
Thanks for the replies, the 1 5/16" fits over the nut just a little loose, probably will give it a try.
Leland
01-19-2006 19:26:11
Been there done that you just have to keep the gun pushed tight again'st the nut at all times .
KEB
01-19-2006 18:58:50
Check your math. 1-5/16 = 33.3375 mm
Converting to decimal, 5/16 = 0.3125, + 1 = 1.3125
1.3125 in x 25.4 mm/in = 33.3375 mm
The 33 mm socket might be a little tight, depending on the tolerance of the nuts, as 1-5/16 is slightly larger than 33 mm. If it'll go over the nuts, shouldn't be any problem with it slipping or rounding off the edges of the nut.
Keith
KEB
01-19-2006 19:01:26
 Re: 1 5/16 vs 33mm in reply to KEB, 01-19-2006 18:58:50
Oops, just re-read your post. 1-5/16 inch will be a little bit loose, but on a nut that size I can't imagine the extra 1/3 of a millimeter making that much difference, particularly if its a 6-point socket. I'd probably go for it unless I could feel a lot of slop.
Keith
kraigWY
01-19-2006 18:49:02
1 5/16 is 26.987 5 millimeter which is closer to your 27 mm socket
Alan Y.
01-20-2006 15:08:55
 Re: 1 5/16 vs 33mm in reply to kraigWY, 01-19-2006 18:49:02
Kraig, 27mm is actually close to 1 1/16, not 1 5/16.
