Are you talking a knee wall ( short foundation wall with footing ) and a slab ? I like that idea, especially for a building that is to be enclosed, curious as to what the detail would be at the column, would you drop the column ( pole ) below grade and encase around it or leave it above grade, encased in concrete, with some sort of base plate connection embedded in the concrete, I've pondered this myself, 3 concerns are; structural, decay of the column bases and frostline. I've always wanted to build one similar and keep the columns above grade somehow, even though .40 or .60 CCA pressure treated may not require this, I'm always overkill, has to last 100 years LOL ! On the concrete, just take the dimensions of your form(s), I'll use the slab for example, say 30'-0" x 40'-0" = 1200 sq ft. x thickness of slab = 6" divide 6" into 12" ( 12" = 1 foot ) you get 0.5 as a decimal to multiply so 1200 x 0.5 = 600 cu. ft. divide by 27 ( 27 cu. ft. in one cu. yd.) = 22.2 cubic yards of concrete x $90.00/cu. yd like it is around here = $1998.00 not including reinforcing like 6"x6" woven wire mesh, or rebar, and this does not include forming, placing, finishing, stripping of forms. Also with this quantity I'd order 23cu. yds., hate to be short, so a little extra is not included usually 1/2 to 1 yard over will suffice, been there done that, just the cost of doing business If you do plan some sort of knee wall, take the dimensions and multiply to get the cubic footage, of say a footing and the wall, then do the above math to get the cubic yardage, if the wall is 12" thick, then multiply by 1 to get the cubic foot volumn, less then 1 foot or 12" take that thickness dimension and divide by 12 to get the decimal equivalent of the thickness to plug in for the cubic foot volume. Most likely you will contract it out, and if so, at least you can get an idea of material cost up front, then ask the contractor how many days to do the job, you can then plug in his estimated labor cost and arrive at an accurate number to compare with others, also helps you from getting gouged, some of these guys will throw a high number at people just to see if they will bite.
