Tool Talk Discussion Forum
Tourch problems
old
01-19-2006 10:35:02
My hot wrench or tourch which ever you want to call it has been giveing me problems. It works good to heat things up but if you want to cut something and hit the O lever to push the slag out of the way it just sort of stops the cut, ya it pushes a little out but not like it should. Is it the tip or is it the tourch its self?? Any ideas on that one??
Thanks
T_Bone
01-20-2006 08:59:25
 Re: Tourch problems in reply to old, 01-19-2006 10:35:02
Hi old,
The center orifice on the tip is for the cutting oxygen. If your oxygen valve, at the mixing body (where the hose attachs) is turned fully on, then it's most likely a plugged orifice. If not there then check your cutting lever valve (highly unlikely).
Never use more than 15psi acetylene. A good pressure setting for cutting upto 1" plate is 30psi Oxygen and 5psi Acetylene.
Here are some suggestions I've posted in past threads:
A trick I use for accurate free hand cutting is using a sanding disc to knock off the heavy scale and then use a scratch awl for my lines. The line is very thin so it makes following lines very easy.
Another is to stop cutting when you feel your hands or torch get out of balance. When that happens, stop and reposition the torch then continue cutting.
The cleanest cut comes from a clean tip. After you clean all the orifice bores in the tip, fire up the torch and set flame for cutting, then depress the cutting lever and observe the flame.
There should be a long very "uniform" inner flame cutting cone. If that inner cone is not "very" uniform then your cut will be ragged just like the flame cone is and the back of the metal will have slag. Reclean the center orifice until it's very uniform.
A cut with a clean tip will have a very smooth cut surface with very little (if any) slag on the backside of the cut. If either one of these is not present reclean the tip.
The center bore orifice can get deformed and the tip needs replaced or cut off. It's really important to hold the cleaning file straight in the bore hole and just removing enough material to clean the bore to make the tip last a long time.
I've never used a new tip that was clean enough for cutting right out of the box.
To expand on my thoughts:
Altough theres many different tip sizes, I have a found a No3 makes for a all around good cutting tip as it will cut upto 1-1/2" or 18ga sheet metal depending on the preheat setting.
Another consideration is as the tip size becomes smaller so does the orifice size and it becomes a bare to clean them ity bity holes. If using an automatic cutting machine then changing tip size would be a production benefit.
Setting the proper neutral preheat flame, the orifice holes around the center cutting orifice, can be observed by the tip of the inner flame cone. A neutral flame has a blue colored flame outer sheild with a light blue to white inner cone flame that is slightly rounded at the cone tip. A oxidizing flame (too much oxygen) has a sharp pointed very white inner cone. A reducing flame (not enough oxygen) would have a very round to a ragged thrid inner cone.
T_Bone
old
01-20-2006 10:10:10
 Re: Tourch problems in reply to T_Bone, 01-20-2006 08:59:25
Maybe I should expalin a little more about this thing. The Oxg. valve to set the flame the one closes to the tip hasn't been shutting off so I have to use the other valve to start the setting. Then when I hit the lever to start a cut I get an odd flame, sort of a yellow flame which I know isn't right. Thinking I may need to replace the tourch part of the system or have this one rebuilt. What do you think. Been a welder for years and have worked around these thing for years but never had one do this to me before. I tried a differant tip and it did the same thing.
Thanks
T_Bone
01-20-2006 21:25:04
 Re: Tourch problems in reply to old, 01-20-2006 10:10:10
Hi old,
Ok, now I understand more. You probably have a air leak into the cutting head along with the oxy valve being plugged.
Call your gas supplier and ask what they want to rebuild your cutting head. Sometimes it's not worth messing with yourself.
T_Bone
JMS/MN
01-19-2006 14:40:53
First thing I do with a bad working torch is run the cleaners through it. (given that the gauges are set right- about 7-20 for heating, 7, up to 50 for cutting) Then, if I notice that the end is flat, 'cuz I've been using it like a hammer, to knock off the cut piece.....time for a new tip. $15-20 mistake, but it is really tempting to just give it a nudge..... ..instead of doing it right!
