Tool Talk Discussion Forum
# of cords in log length woods??/
diggerdave
01-19-2006 06:02:36
Hi- can anyone offer any tips on how to best determine the number of cords in log lenght wood? (meaning the wood is not cut and split yet) I am interested in purchasing wood this way but how do you know what volume you are getting? Any thoughts are appreciated. dave
in sticks
01-21-2006 18:45:56
 Re: # of cords in log length woods??/ in reply to diggerdave, 01-19-2006 06:02:36
one ten wheeler with log length wood 7 to 8 cords
Dave NE IA
01-20-2006 16:03:07
Perhaps this is not the exact answer to your question but rather a referance. Simple way to imagine a cord is a full size pickup box is 8ft long with tail gate up---It is 4 ft between the fender wells. That is two fo your measurements now you would have to stack it 4ft high. Dave NE IA
Kendall
01-20-2006 12:02:09
Whild on the subject of firewood.....
click on the link below,
then click on VIDEO GALLERY
and then if you have broadband internet click on-
"Complete 10 Minute Product Movie Download"
Yee Ha! git-r-done!
Kendall
01-20-2006 11:41:18
using the basic formula for a cylinder, pi*radius of the base squared*length, then a 12inch diameter log 8 feet long will be approx 6.28 cubic ft. Since a cord is 128 cubic ft, then you need 20.38 8ft logs 12inches in diameter.
sammy the RED
01-20-2006 05:35:59
A cord of wood equals:
# 30 Boston rockers or
# 460,000 personal checks or
# 61,370 No. 10 envelopes or
# 1,200 copies of National Geographic magazine or
# 12 dining room tables that each seat eight people or
# 89,870 sheets of letterhead bond paper or
# 942 one-pound books or
# 1,000 to 2,000 pounds of paper (depending on the process used) or
# 7,500,000 toothpicks or
# 4,384,000 commemorative-size postage stamps or
# the amount of heat equivalent to what is produced by a ton of coal or 200 gallons of fuel oil.
naz
01-20-2006 02:13:55
Here is a site with wood/log calculators for all different types of wood.Hope it helps,
Naz
Slowpoke
01-20-2006 00:38:32
Make a rack from angle iron or 2x4s, 8' long, 4' wide, 4' high.
Cut the wood in 4' (or 8') lengths. When the rack is full, you have a cord.
Really
01-21-2006 05:42:32
 Re: # of cords in log length woods??/ in reply to Slowpoke, 01-20-2006 00:38:32
Slowpoke your name fits well!
Slowpoke
01-21-2006 14:12:08
 Re: # of cords in log length woods??/ in reply to Really, 01-21-2006 05:42:32
Thanks!
Kendall
01-20-2006 11:50:31
If you filled your rack with logs, you would be cutting yourself short. Round logs wont take up the same space as split wood since split wood packs tighter than plain logs. In my calculation above, sixteen 12inx8ft logs would fill a 4x4x8 space but calculations show that it will actually take 20 logs to make a cord. Of course that would be perfectly packed wood so in reality it's probably gonna be less.
350 HU Don
01-19-2006 17:47:42
A cord of wood is a measure, 4'X4'X8'. As someone else said, it's 128 cubic feet. So a stack of wood 4' high by 4' wide by 8' long would be a cord. Sometimes there are approximations of a cord using weight, but those are subject to a lot of interpretation or misinterpretation as the case may be. Variance can occur because of the species of wood, the amount of moisture in the wood, so it's not a very accurate measure of a cord.
Hermit
01-19-2006 17:38:49
Here's a guide if you're out in the woods harvesting trees. Hope this helps. Tree diameter measured at chest height.
4 inch trees--50 trees per cord
6 inch trees--20 trees per cord
8 inch trees--10 trees per cord
10 inch trees--6 trees per cord
12 inch trees--4 trees per cord
14 inch trees--3 trees per cord
Matt Smith
01-19-2006 14:42:21
128 cubic feet per cord.
steve from mo - dangit!
01-19-2006 08:17:52
 Some answers. in reply to diggerdave, 01-19-2006 06:02:36
If you are having it delivered by truck, a cord of hardwood is 5800 pounds, and pine is 5350 pounds. If you are cutting standing timber, it gets a lot more complicated.
http://www.utextension.utk.edu/publications/pbfiles/PB1628.pdf
