Tool Talk Discussion Forum
Torpedo Heater-Part 2-2 Regulators
pbutler
01-16-2006 10:11:59
Ok, I understand the issue now. My propane guy tapped the high pressure line but put a regulator outside the shed. Then I put the regulator for the torpedo heater inside-so there are 2 regulators.
Now the only question is are all regulators the same? If so I think I can just remove the one inside the shed and be done.
Mike M
01-17-2006 09:47:08
 Re: Torpedo Heater-Part 2-2 Regulators in reply to pbutler, 01-16-2006 10:11:59
Normally for on the big tanks you have 2 regulators a First Stage at the tank that drops tank pressure down from ( for instance but not for sure )200 psi to 10psi ? that way it still has enough pressure to get the flow through the piping that can be several hundred feet. Then you have a 2nd stage outside and right before it enters the building these drop from the 10 psi ? or whatever down to ounces of pressure or water column inches you need a special tool called a mamometer to measure this pressure. These are really very easy to make I did a google search last year and found plans to make one out of a board and some clear plastic tubing. Very handi to have one to test your final pressure so as not to blow yourself up !
Kendall
01-16-2006 15:35:35
I think you propane guy thought you were going to run a space heater, which is a low pressure appliance. The heater you have runs straight off the tank pressure and has its own regulator. You need to either bypass the regulator outside your shed, or exchange it for one with same pressure as the one on your torpedo heater.
There ARE different pressure regulators. The one for you grill is different then the one for your catfish fryer,for example. I can crank up my catfish fryer and it looks like the business end of a Satern 5 rocket!
pbutler
01-16-2006 15:45:24
 Re: Torpedo Heater-Part 2-GOT IT! in reply to Kendall, 01-16-2006 15:35:35
Thanks to everyone! I removed the 2nd regulator-the one that came with the heater.
It now works great!
T_Bone
01-17-2006 08:25:39
 Re: Torpedo Heater-Part 2-GOT IT! in reply to pbutler, 01-16-2006 15:45:24
Hi pbutler,
I would suggest you change the gas connection on the heater to a different connection not found on other heater units of that same type. Why?
If someone other than you hooks this heating unit up to a stardard cylinder then try's to fire off the unit, you can expect a huge explosion as you have removed the pressure regulator and the unit would receive high pressure vapour, or vapour that it's not design to run on.
If it has a different gas connection to a cylinder that would atleast stop them from direct connecting it to LP cylinder without asking a few questions and having to change some componets.
T_Bone
Coloken
01-16-2006 11:14:02
I just read your original post again. better get expert advice. Was the heater designed to run right off of the bottle? If so, it wont run right with regular regulators and bringing in high pressure from the tank is a no-no. Find a better source than us guys that can't see it.
Coloken
01-16-2006 11:00:27
I think most common propane regulators would be the same. That is they reduce to the same pressure. When I was a kid, I had one that was adjustable over a limited range. Natural gas regulators look the same but use a diferent pressure. Plenty of people here know what that is. I question if he ran the pipe from the tank at high pressure, then the regulator at the shed. Don't think I would want up to 200 pounds pressure (on a hot day) in the pipe. The usual is to have the regulator right at the tank with special pipe between. Could there be a regulator at the tank and then another at the shed?
pbutler
01-16-2006 12:08:21
 Re: Torpedo Heater-Part 2-2 Regulators in reply to Coloken, 01-16-2006 11:00:27
No, I don't believe there is. The reason is probably because the house is about 200ft away from the tank-so they just ran high pressure underground and hung the regulator on the side of the house.
My guess is when he came back to do the shed he just did the same thing.
Red Dave
01-16-2006 10:59:41
You ought to call your "Propane Guy" and find out for sure. He has been there and seen what you have, not guessing over the internet.
The results of getting it wrong can be catastrophic. Why take a chance?
Just how I see it. Others may see it differently.
