Hi Ya"ll - I wasn"t sure where else to ask a question like this - haven"t found too many leads elsewhere... I"ve got a 1997 Mercury Cougar car with about 180,000 miles on it. It"s been a great car - no problems - until last night. I was slowly backing out of a concrete drive and turned pretty sharp at very low speed - I heard a pop under the car, but couldn"t find anything wrong. When I took off, the front-end was jumping as if I"d busted a tie rod end and a front wheel was flopping around (have had several of those happen on pickups and one on the truck out at the farm). I limped it home - it steers fine going down the road, except for "jumping" around while backing up or turning at low speed - it feels a lot like turning sharp in a Suburban in 4-wheel drive. I jacked it up and can find no looseness in either front wheel - can"t find any linkages loose or broken - the wheels turn exactly in tandem with each other, etc, but something is definitely loose... I"m not sure if the steering wheel is tracking exactly where it did before while going straight, but I can"t get it to "jump another tooth" if the steering gear box is loose enough to allow that... Any ideas on what else to check??? Thanks for any advice, Howard H.
