Tool Talk Discussion Forum
Standard Pickup Bed - Dump Conversion
Joe MD
01-12-2006 09:11:59
Does anyone have any experience with these pickup truck dump bed conversions. I have seen both steel and rubber pillow types.
My gut tells me they are worthless junk and will destroy the weight capacity of my bed, but it sure would be nice to not shovel for an hour everytime I get some stone.
I have a 2002 F-250 with 8ft bed.
Thanks in advance.
Fawteen
01-13-2006 01:24:09
 Re: Standard Pickup Bed - Dump Conversion in reply to Joe MD, 01-12-2006 09:11:59
I've had one under the bed of my '89 Chevy tonner almost since it was new. When I installed it, I put in a subframe to spread the load at the point where it attaches to the floor of the bed, and I put the power unit behind the seat instead of inside the frame rail.
About 2 years ago I broke a weld on the scissors link. When I took it apart to fix that, I replaced the bumper brackets with heavier, fabricated units, straightened and reinforced the brace over the rear cylinder mount, and added grease zerks to the toggle on the scissors link.
I'm still on the original box. Most of the loads have been construction debris and brush, but I have hauled dirt/sand/rocks in it quite a bit too, and abused the heck out of it by overloading it (that's how I broke that weld..)
It's been handier than a pocket on a shirt, and I'd buy another one in a heartbeat.
shannon from ohio
01-12-2006 18:53:04
www.ezdumper.com
jokers
01-14-2006 15:36:18
 Re: Standard Pickup Bed - Dump Conversion in reply to shannon from ohio, 01-12-2006 18:53:04
I`ve got the powder coated EZ Dumper and other than rusting badly on the outside in the first year, it even damaged the paint on my 04" Dodge 3500 with rust deposits, it seems like a pretty good outfit. It will easily dump anything that I can get into it.
Regarding the rusting, I contacted EZ Dumper and the company I bought it from, North South Trailer sales in Boonville, NY and they both told me to "stick it!", they were too busy to deal with a warranty claim for repair of the powdercoat. Seeing as how all of the slide in units are essentially the same, my next one will be a different brand.
Russ
Ryan - WI
01-12-2006 18:45:13
have you looked into the crank operated bed liner? Shouldn't hurt capacity hardly at all and lots less hassle. At 150 bucks it might be worth a shot. I would think it possible to repalce the crank with a motor and pulley.
bradk
01-12-2006 17:39:09
I installed one from Northern tool a couple years ago in a 3/4 ton 93 chev.After getting bugs worked out,it's used almost daily by the owner as a hauler of household demolition.The biggest headache was fabricating the bumper brackets which makes the rear bumper tilt w/the bed.The thing to keep in mind is to not over-load,otherwise,they're a fine unit.~brad
RustyFarmall
01-12-2006 11:05:29
I've found a very good solution to the problem, by the time I figured in the cost of fuel, my time, and wear and tear on the truck, it is much cheaper to hire it delivered, 12 to 15 tons at a time, and spread it out as needed. The trucker charges the price of the rock per ton, times two. I can't even begin to do it at that cost.
Butcher
01-12-2006 10:43:42
We had a Maxi dump on truck at work. Really nice unit. Very well built. You loose alittle load capasity because of the extra weight though.
buckva
01-12-2006 10:34:30
Had one of the ones that go under the bed and the entire bed lifts up. that was one slick trick. some flex in the bed but never damaged it. Unit would not fit replacement pickup or I would have kept it.
old
01-12-2006 10:28:58
Well if you want to keep the bed you have and ad a unit then I'd say use a shovel, your bed will not hold up well. I know a guy that got one and it worked ok but he made his own bed and frame for it. The sldie in units are about the only way to go and if done right can be removed when your not useing it.
steve from mo - dangit!
01-12-2006 09:46:28
 Maybe a slide-in unit? in reply to Joe MD, 01-12-2006 09:11:59
I"d have to agree about the conversion units. The only one I ever saw that I liked put a subframe under the truck bed to control flex.
The city and the state highway department have started using steel slide-in units so they have to be pretty durable.
