Tool Talk Discussion Forum
Homelite Super XL Carb Settings
Old Hickory
01-11-2006 09:14:00
Would appreciate if someone could tell me the initial carburator settings for the high and low jets and idle screw for a homelite super XL.
Old Hickory
01-13-2006 15:00:08
 Re: Homelite Super XL Carb Settings in reply to Old Hickory, 01-11-2006 09:14:00
thanks for the information. I got her started. Thanks.
ex-racer
01-11-2006 17:00:13
The settings suggested by Teej should get it started.
Then, with the saw warmed up, set the low-speed screw so that it idles smmoothly, and the idle-speed so that the chain just stops running.
Then with the saw cutting under load, set the hi-speed screw for smooth operation (not four-cycling) and maximum power. (Be careful. - This usually requires two people.)
You may have to repeat the procedure a second time to get it just right, because changing each setting has some effect on the other.
Ed
dave
01-11-2006 12:58:47
might check here.
Teej
01-11-2006 10:32:50
For most chainsaws, and 2 cycle engines, 1 to 1-1/4 turns for both. Its always worked for me. 1-1/2 turns for 4 cycle lawnmower engines.
