Hi Richard, I would not want my main doors facing the storm side of the shop because when a strom does hit you can't keep water, dirt, leafs etc: from entering the shop. Put the doors where there the most handy for you and use other means for venting the shop. Roof wind powered turbine vents are very effictive if the roof has the proper pitch. The higher the pitch the cooler the shop will stay without insulating. Remember heat rises so use that to vent the shop. A normal house needs 4 air changes per/hr for comfort and a shop would need about 30 air changes/hr for comfort. That would mean you need 9000cfm of air venting for your size of shop. They also make a vented ridge cap that lets hot air out but keeps water, etc: out. If a over lapping roof ridge design is used then no additional roof venting is required but not too many people like this design any more but is how the old timers did it. If you screen the windows, remember screen cuts the air flow down by 75%. You can use a natural cool air under ground system . This uses a under ground space, pipes, chamber void, water trap, etc:, 8ft under ground. At 8ft the ground temp does not change temperature year around. If you run your electrical under ground, besure to use plastic pipe for the wires. See plastic pipe does have a use! Too many rodents like the taste of wire insulation. If you bury it deep enough 24", I used 1/2" sch10 PVC, one for each wire, and yes I know it's against code!!! but it was cheap and mine was not a code install. T_Bone
