Mig welding and spatter
Robert J Spence
02-16-2001 16:11:53
I would like to know if wire speed has a direct bearing on weld spatter?
I do notwant to lower the voltage if I can avoid it.
I am using an inverter as a power source with arc foce adjustments, .045 wire, Ferramax gas ( a Weldco Product).
Steve U.S. Alloys
02-17-2001 06:04:25
 Re: Mig welding and spatter in reply to Robert J Spence, 02-16-2001 16:11:53
Wire speed determines how many amps are being drawn from the machine at any given amperage setting. If your excess spatter is a result of too much wire speed, it should be obvious that the machine is also welding way too hot.
More likely than not, the spatter originates from an incorrect travel angle (use the backhand technique), a voltage setting that is too low, arc blow (scroll down to previous post), or you are holding your nozzle too far away.
T_Bone
02-16-2001 20:18:20
Hi Robert, sure does but Mig is gonna splatter no matter what. They do make a anit-splatter spray that works well on SS but is really not needed for mild steel. You also can use Argon while welding mild steel for almost no splatter but more costly. Your wire speed should be adjusted to sound like bacon frying for a given arc length/voltage.
I would suspect your invertor is causing some problems because it's not a "true" sine wave inverter, but probablly more like a modified square wave even tho it's advertised as a sine wave inverter. You could prove this by running off grid power for a comparrision.
Your wire size of .045 is awful large for normal work if welding with a non-automatic setup! Travel speed is very important with .045 than with .035 implying it takes more concentration.
A twisted wire cup wheel on a 7.5" side grinder will remove 99% of weld splatter very quickly.
T_Bone
