Tool Talk Discussion Forum
Tap Extractor set
carman
01-03-2006 17:00:41
I got a big box of tools at the junk yard last week, And in there were tap extractors I do'nt know what there are or how to use them any help I do use my tap&die set thanks carman
Fawteen
01-04-2006 11:57:36
 Re: Tap Extractor set in reply to carman, 01-03-2006 17:00:41
What the other fellers said. Mostly, they are used to fill up what little space the broken tap left in the hole and extinguish any hope of ever getting the tap out with anything less than a tactical nuclear device.
Davis In SC
01-03-2006 18:02:54
Most likely , they are Walton Extractors...They are a nice tool, but I have only had limited success using them. A tap that is stuck very tight will break off the fingers. If you use them, let the tap soak for a while with a penetrant, Then, gently try to twist the tap in both directions to break it loose. Often, the metal gets displaced at the point the tap broke off at, & that is what prevents it being easily removed...
old
01-03-2006 17:39:13
They are used to remove a tap if you brake one. The ones I have seen had pins that would push down in the flutes of the tap and then you could turn the tap back out of the hole, or at least that is how they should work but I have never had any luck with them.
