Tool Talk Discussion Forum
Dearborn Tractor-Lift-----support pads?
Ron Lindquist
01-03-2006 08:29:11
Saw on a Web Page piectures of the lift---have to get one. It says at one time You could get pads to use with it on soft ground. Has anyone ever seen them , have a picture, or other info.??
Thanks,
Ron
JohnNoregon
01-04-2006 00:22:53
 Re: Dearborn Tractor-Lift-----support pads? in reply to Ron Lindquist, 01-03-2006 08:29:11
hey ron go tow the n forums check the comments there got it all
JohnNoregon
01-03-2006 21:10:34
Hey Ron on a CD that I bought that has all the N manuals there is a description of the tractor lift and all of the measurements to build them. am out of town at this time or would send then to you if you dont fine them by the end of the month will see if I can find it in all my boxes. JohnNoregon
JD9295
01-03-2006 18:27:55
there is one for sale in the photo ads on here
JoeK
01-03-2006 14:30:07
Used one many times growin up Ford Farming,to lift the rear,and reverse the wheels for cultivating.Never had the pads as it was done on a slab poured alongside the barn for such jobs and parking machinery on.Wouldn't take much,just a foot square plate or such under each corner to keep it from cutting in.Unless tractor is weight/fluid loaded heavily I seriously doubt you'd have any any problem on packed ground or good sod.Couple of points here.
*The tractor(Ford N-800/Fergies)is lifted/held by it's own 3pt hydraulics.If your hydraulic system is weak or leaks down quickly you're gonna have problems.
*Let common sense prevail,these jacks are nominal for lifting the tractor,but NOT overbuilt or equipped w/idiot proofing so lock up the kids/dogs etc and NEVER EVER get or reach underneath the tractor without additional jackstands/cribbing in place!
*Heaviest lift I've done was a Jubilee w/loader frame,fluid ballast,and full hvy pie weights..lifting rears only was a challenge and "creak&groan"time for the jack until let down on oak blocks.
*Carefully inspect any used/old jack before use,as again...they were NOT overengineered,just strong "enough".Any cracks or heavy rust could be both you and your tractors downfall.
Sorry to rant,but these jacks are kinda like a buzzsaw,handy but Deadly without due care.
jhill
01-03-2006 13:45:04
I have seen several of the lifts but never any support pads. I would like to see drawings or pictures also.
NEsota
01-03-2006 09:03:31
If you are talking about the unit that uses the two point lift arms, on an 8N type, to raise the front and rear wheels off the ground, I think one inch thick wood scraps could act as pads.
Ron Lindquist
01-03-2006 17:41:47
 Re: Dearborn Tractor-Lift-----support pads? in reply to NEsota, 01-03-2006 09:03:31
Thanks, for info. I have a lot of wood I could use but looking for original factory for engineering. Was also thinking about a metal rod the size of the jack tube I.D. that could be pined, attached to a--maybe foot square piece of 5/16" plate, or so for the back and a 3-4 foot piece of plate with maybe 2--- 1/2" x 1/4" bars welded, to form a channel that the front piece bottom would fit into.???
Ron
