Tool Talk Discussion Forum
Speaking of bandsaws
Tom in TN
01-02-2006 20:44:11
I have access to a small bandsaw - I think it cuts about 8" - 10" inches. My question is this, is it possible to get a special blade for butchering animals and just use it on a regular old bandsaw? You can tell I don't know much about bandsaws or butchering!
I'd like to butcher a deer this winter, and if it's possible to get a meat blade, I'd like to do so.
Thanks for any advice.
Tom in TN
Bernie in MA
01-03-2006 14:25:10
 Re: Speaking of bandsaws in reply to Tom in TN, 01-02-2006 20:44:11
I have a 2' handsaw I bought from Sears years ago. The teeth are small and spaced about 1/8" apart. Probably any blade like this would work. The biggest problem I think would be cleaning off the wood/metal chips before and meat afterward.
David - OR
01-03-2006 12:01:29
Using a saw of any sort for butchering deer is a bad idea. Much of the gamey taste is in the marrow, fat, and connective tissue. Using a saw smears the good meat with marrow and fat. A hand meat saw (like a big hacksaw with a special blade) is handy for splitting the hindquarters and cutting off the lower legs, but don't try to make "T-bone steaks" by sawing through the backbone.
The best way to cut up a deer is with a filet knife. Separate the muscles from the bones with your fingers and a knife blade. The best meat is the backstraps and tenderloins, which are very easily separated from the ribcage and backbone. The hindquarters are also good, but the different muscles have different degrees of tenderness and cutting the steaks is a little trickier. In all cases, cut your steaks perpendicular to the grain of the muscles. This makes for more tender eating. Wrap meal sized portions them using a vacuum packer or enclose one portion in a freezer back, then put multiple servings together in a larger freezer bag, giving you two layers.
With practice, you can bone out and wrap a deer in 2 to 3 hours.
