Tool Talk Discussion Forum
Hyd. Control for a Salter
lenray
01-02-2006 16:20:42
Have a control in my dump truck one lever two knobs--dials with numbers on them. It is hooked up to Hyd. Hoses.
Thinking it is for a salter---if you need one come and get it--FREE
michigan
Gus
01-03-2006 08:40:55
 Re: Hyd. Control for a Salter in reply to lenray, 01-02-2006 16:20:42
Where are you in Mich.?
lenray
01-03-2006 09:01:05
 Re: Hyd. Control for a Salter in reply to Gus, 01-03-2006 08:40:55
Hello Gus
60 miles north of St. Johns---200 miles south of the SOO.
RJ-AZ
01-02-2006 19:43:38
That is a hyd control for a V-box sander. One knob sets the rate for the drag chain and the other is for the spinner. The lever is for on or off. This is a real handy valve for cotroling two hyd motor function on one primary circuit.
LENRAY
01-03-2006 07:07:23
 Re: Hyd. Control for a Salter in reply to RJ-AZ, 01-02-2006 19:43:38
Thanks for the good info. concerning the valve.
Gus
01-02-2006 16:32:47
Are the hoses hooked to your pto pump? Is the control dash mounted? Where are you in Mich? Gus
lenray
01-02-2006 18:00:15
 Re: Hyd. Control for a Salter in reply to Gus, 01-02-2006 16:32:47
The unit sits on the floor of the cab. Truck has a front mounted hyd. pump.
There are hoses to the pump and hoses to this control and hoses to the dump lift and also hoses going back to the hyd. storage tank.
I would like to have this unit removed but need the other stuff to continue to work. It is a 1977 Ford F900--formerly a county truck.
Thanks for your inquiry.
lenray
01-02-2006 17:59:27
lenray
01-02-2006 17:59:06
