Plasma Cutter,50 A Plasma Cutter, Arc Voltage 100 Volts, Current Rating 50 Amps, Open Circuit Voltage 260 Volts, Primary Input Voltage 208/230 Volts, Input Current 60/55 Amps, Output Current 50/40/30 Amps, Gas Supply 4 CFM, Pressure 65 PSI, Overall Height 33 1/2 Inches, Overall Depth 20 1/2 Inches, Overall Width 22 1/2 Inches, Cuts 1/2 Inch Metal Includes Wheel Kit, Handle for Mobility, Cable Wraps for Cord Storage, 25 Feet Plasma Torch, 15 Feet Ground Cable, Air Pressure Regulator, Plasma Torch Consumables Kit. PARTS LIST - DAYTON 5Z031 Manufacturer/Brand: DAYTON Model #: 5Z031 Description: Plasma Cutter,50 Amp Additional Model Info: C Number of Parts Listed: 54 Manufacturers may change products over time. To get the right parts, be sure you have the right model. Match the Additional Model Info (above) to your unit's nameplate/label. Manufacturer Part # Description Ref. # Notes 068-024-666 Push Hubs 1 413-030-666 Wheel with Hub 1 47350 Helmet 1 413-048-666 Axle 2 47120 10 Shaded Lens 2 Contact Us 412-329-016 Wheel Mtg Brackets 3 Contact Us 47150 Clear Lens Cover Plate 3 Contact Us 332-333-300 Head Gear,standard 4 Contact Us 415-617-000 Base 4 Contact Us 412-328-016 Foot 5 252-004-000 Pressure Switch 6 Contact Us 246-206-666 Gas Solenoid 7 Contact Us 415-621-140 Front Panel 8 Contact Us 312-117-001 Nose 9 Contact Us 238-456-000 Torch W/safety Switch, 50amp 10 44160 Torch Standoff 13 Contact Us 334-290-905 Nozzle Cap 14 Contact Us 334-288-908 Swirl Ring 16 238-228-666 Cable, 6 Ground 17 Contact Us 239-015-152 Ground Clamp Assembly 17 Contact Us 254-004-666 Regulator 18 251-003-666 Pressure Gauge 19 246-225-666 Power Switch 20 246-222-666 Switch, Amperage Selector 21 Contact Us 246-224-666 Knob 22 Contact Us 246-226-666 Run/set Up Switch 23 Contact Us 880-152-666 Control Circuit Board 24 Contact Us 880-181-666 15-pin Wire Harness 25 Contact Us 880-139-666 9-pin Wire Harness 26 Contact Us 246-199-666 Pilot Arc Relay 27 Contact Us 880-141-888 Transformer 28 Contact Us 880-156-888 Control Transformer 29 Contact Us 244-080-666 Rectifier 30 254-005-666 Pre-regulator 31 216-053-666 Breaker,thermal 32 Contact Us 245-155-666 Resistor, 2ohm, 240 Watts 33 Contact Us 216-086-666 Motor,fan -230v 34 Contact Us 316-007-300 Fan Blade 35 Contact Us 415-730-015 Back Panel 36 Contact Us 248-178-666 Power Cord 37 Contact Us 246-165-666 Contactor 38 Contact Us 880-134-666 Resistor Assembly 39 880-137-888 Reactor 40 332-204-000 Tig Torch Head Contact Us 334-289-908 Nozzle, Hi Current Contact Us 412-332-115 Handle (not Shown) Contact Us 415-530-040 Access Panel (not Shown) Contact Us 415-630-150 Cover with Access Panel (not Shown) Contact Us 44050 O-rings Contact Us 4424 O-ring Lubricant Contact Us 44500 Electrodes Contact Us 44540 Nozzle Low Current Contact Us 4Z034 Contact Grainger Branch Contact Us 4Z035 Contact Grainger Branch Contact Us Notes Contact Us To see if item/part has a parts list available or is available for purchase, please contact us. Email [email protected]. Or, call us at 1-800-323-0620. Need pricing, availability, or don't see what you need? Contact Grainger Parts at 1-800-323-0620, 24 hours a day, 7 days a week. spacer
