Plow Points
John
11-27-1998 16:03:26
I am in need of two plow points for my plow. They are no longer available from stock. The plow is a Dearborn 3point, 3-14, model number 10-158. According to both the Ford dealer and Massey Ferguson dealer, the points are Massey Ferguson. The part number stamped in the point is 660047M91, three bolt, and there is a lip on the leading edge that goes over the frame. It also has "CANADA" and "MF" stamped in it.
Thank You for any and all help,
John
Tom from Ontario
11-27-1998 19:40:24
 Re: Plow Points in reply to John, 11-27-1998 16:03:26
: I am in need of two plow points for my plow. They are no longer available from stock. The plow is a Dearborn 3point, 3-14, model number 10-158. According to both the Ford dealer and Massey Ferguson dealer, the points are Massey Ferguson. The part number stamped in the point is 660047M91, three bolt, and there is a lip on the leading edge that goes over the frame. It also has "CANADA" and "MF" stamped in it.
: Thank You for any and all help,
: John
John: There used to be an outfit here in Ontario that made ploughshares for Fords, Fergusons, Masseys and Cockshutts. Usually narrow bottom, but maybe they did some wide ones. Will check with my snitch in the local dealer. They were made by Otaco in Orillia. No guarantees but will try. Will be a few days though. Tom
