Tool Talk Discussion Forum
winch
Jack-Iowa
12-29-2005 13:55:26
Been looking at winches and so far not ready to pluck down $$.
Would like a dc with a 10000 lb limit as that is the most I can figure on pulling. Figure I would like to be able to mount on tractor,gooseneck and maybe truck.
what have you been happy with and what short commings?
thanks
Coldiron
12-30-2005 09:41:54
 Re: winch in reply to Jack-Iowa, 12-29-2005 13:55:26
Jack, I have a worm gear Ramsey that is a work horse. I had a winch with the planetary gear that just didnt hold up. The worms cost more but in my opinion are well worth the extra cost if you are gonna be doing a lot of work with them.
RustyFarmall
12-30-2005 04:51:38
I saw this posting yesterday but didn't comment then. I just want to say one thing, check the size of the cable that is on the winch. A winch that is rated for 10,000# needs to have minimum 3/8" cable. I think you will find that the rip-off winches all use 5/16".
Hawaiirocky
12-29-2005 22:15:42
I have three of the Chinese winches, and had to replace one of them just today, after one year of fairly heavy use. I wouldn't use them on anything where your safety is involved, I just drag stuff around as needed, and watch out. The cables that come on them rust out almost immediately. Basically, they are functional but cheaply made.
Slowpoke
12-29-2005 20:54:59
I'd rather not have to mess with dead batteries, corroded cables, theft, etc, fom non use, so I bought a like new 1200lb manual Dutton-Lauson at the flea market for $15. It has a disc brake so if I stop cranking to make steering adjustments on a vehicle it stays put. When there is no load on it it's kind of a pain to pull it out, but when backing off a load it stops if I stop cranking. I use a single block at the vehicle to double the pull power. It's mounted on the trailer tounge with 2 pins, so I can remove it for storage. I would later like to change to a larger capacity like 2500 lbs. Grainger lists one for $168 that holds 70 feet of 5/16 cable.
JD9295
12-29-2005 14:23:20
go ahead and spend the money for a warn winch and be done with it. also find a good block and tackle to throw in the truck, it will increase the capacity of the winch.
Davis In SC
12-29-2005 19:11:31
 Re: winch in reply to JD9295, 12-29-2005 14:23:20
Warn is the best IMHO... Last thing you want is for a Chinese winch to fail while winching a tractor up the ramps of a trailer... With reasonable care, a Warn should last a lifetime of occasional use...
Jack-iowa
12-29-2005 18:30:42
the specs do not sound any dif than the china ones I looked at and the price is alot more. Any experience?
