Tool Talk Discussion Forum
Tubing Bender
BobOHIO
12-28-2005 16:22:22
Does anybody know of a site that has a set of plans showing how to build a simple manual tubing bender? Would like to be able to bend pipe and flat stock. 1/4 inch is about the heaviest flat I ever use. Thanks
TCoe
01-04-2006 08:22:32
 Re: Tubing Bender in reply to BobOHIO, 12-28-2005 16:22:22
The cheapest bender is the one from HF on sale for $49-69. The die for tubing can be purchased from American or Metalebendingtool.
BobOHIO
12-29-2005 20:12:04
THanks Charley,Uncle,Slowpoke for the good info. I will check those sites. I found a bender at tractor supply for about $90 but it was cheap looking import so figured would rather try and build my own. I used to get a magazine from Hobart called world of welding that I enjoyed. Thanks again I appreciate your help.
Uncle
12-29-2005 18:14:06
Go to www.machinebuilders.net They have alot of plans of this kind.
charley hellickson
12-28-2005 22:08:29
hi Bob.go to hobart welders and click on weld talk.you may have to sign up,register, to get in.i rember i had to to get into the archives.do a search on tube benders.i have read some talk on there about benders.a good site for welding and metal working.my member name on there is charley h. another good site is floor shop talk. hope this helps.good luck.charley.
Slowpoke
12-28-2005 17:05:12
I don't know of any plans, but I have a Harbor Freight bench mount flat stock and rod bender that works very well. I roll 1/4x 1 into 4" rings, although it takes some effort to get the size right. I think you can still get one on sale for $50. It comes with several size rollers but you can make others with a lathe. They also have a floor mount for more $. As far as bending small tubing, you could make some rollers for that, too. Otherwise pipe and tubing benders are available for about the same price as the flat stock bender.
