Tool Talk Discussion Forum
Shop air regulator
Richard H.
12-28-2005 07:48:38
One of the last things I need to do to my shop is to hard pipe air into it. I want to put a T-fitting in for shop air and regulated air + or -10 to 50 psi for spray painting. My shop air is 140 psi. A moisture seperator would be nice too. Anyone got a set up like this and if so where did you find it? Richard
Dean Lydey
01-01-2006 17:15:43
 Re: Shop air regulator in reply to Richard H., 12-28-2005 07:48:38
I'm a newbie to the antique tractor world, but finally a forum topic I can help with. I design and sell pneumatic automation systems from 8-5. I agree with everything mentioned before me and would only like to recommend a coalescing filter. These are different from the standard filter or water trap in that they actually "coalesce" aerosol water and oil into larger droplets that can be removed. The differnce in air quality is fairly dramatic. Especially if your painting with the compressed air, it's worth the effort. Expect to pay $50-100 for a 3/8npt coalescing filter. A quality pneumatic automation distributor in your area can help. www.numatics.com would be a good place to start.
Charles (in GA)
12-28-2005 17:05:10
You really should consider regulating the whole system down to around 100 psi, which is much more usable than the higher pressure, since most air tools are designed for 90-100 psi and pressures above that can cause more pipe blowouts, failures, etc.
In any case, www.surpluscenter.com is a real good source of regulators, expecially small 3/8 and 1/4 pipe thread models, plus combo water separators and regulators, etc. Link below is for a 1/2 pipe thread unit that would be a good whole shop regulator.
Charles
Keith-OR
12-28-2005 09:46:24
For spray painting you need a dedicated outlet with controlable regulator and seperate airfilter/moisture trap.
I even use a disposable air filter on my spray gun for final filtering.HTH
Keith
GregCO
12-28-2005 09:19:52
Here you go. I have one of these and they work very nice.
Richard H.
12-28-2005 15:27:51
 Re: Shop air regulator in reply to GregCO, 12-28-2005 09:19:52
Thanks Greg, I found a "Sharpe" today close by. Dryer and regulator for $125.00. I thought I got all I needed to plumb it in but I think it should have a ball valve to turn it off when not in use. What do you think? Thanks again Richard
GregCO
12-29-2005 07:44:31
 Re: Shop air regulator in reply to Richard H., 12-28-2005 15:27:51
I agree with putting a ball valve in line before it. I have had a few cases where I needed to turn the air off to the regulator/water trap but did not want to shut the entire shop off.
Have fun
Greg
old
12-28-2005 08:41:11
Yep have my compressor set up that way. All I did was plumb in a pipe T and put an water trap before the T and the regulate one side of the T and not the other side of the T.
