Tool Talk Discussion Forum
Someone has to make this...
Ryan - WI
12-27-2005 17:19:30
I am looking to buy a timer for an outlet. My son got a Power Wheels car for Christmas and the charger doesn't have an auto off. You are not supposed to charge the car for more than 18 hours. I am searching for someone who makes a timer that will go that long. All I can find are 24 hour programmable timers. I want something that is just a kitchen type timer that shuts itself off. Kind of like a fan timer for a bathroom. Anyone have any idea on where to find one?
Joe in Iowa
12-27-2005 18:29:20
 Re: Someone has to make this... in reply to Ryan - WI, 12-27-2005 17:19:30
I don't know about whether there is one that will do what you want off-the-shelf, but here is what I have done for my radio controlled airplane chargers: Buy a dial-type 24-hour plug-in timer (the kind with two or four little tabs that you set for on/off by sliding around the dial). Open it up, and you will find that the motor is connected to the leads that plug into the wall outlet, making the motor live all the time. Disconnect one wire from the "live" side, and solder or connect it to the "switched" side. The timer will now run when it is in the "on" part of the dial's range, and stop when the timer turns off. Set the tabs up for an 18-hour charge (like midnight to 6pm). To charge, just turn the dial until it snaps "on" at the midnight setting, and it will power whatever is plugged into it for 18 hours, and then turn itself and its load off. I suggest you check your battery/charger setup to make sure the battery doesn't discharge through the upowered charger while the timer is off. You might be disappointed if the battery was dead after an overnight charge.
I don't know what current your charger requires; check its rating against the rating of the timer to make sure you don't overheat anything.
Good luck
Jon Hagen
12-27-2005 18:37:23
 Re: Someone has to make this... in reply to Joe in Iowa, 12-27-2005 18:29:20
Another way is to use the same little $7 timer with the "turn on" tab removed leaving only the "turn off" tab installed. Set the timer dial to 18 hrs before the turn off setting,manually turn the switch on and 18 hrs later it will switch itself off. With no "turn on" tab installed,the switch will remain off untill you manually turn it on again for the next charge.
