Gas tank cleaning
Ron Kinton
11-26-1998 22:30:16
I have several tanks from tractors and engines with "varnish"
in the tank, and a Farmall H that is real bad and it has a baffle
which makes it impossible to clean mechanicaly. Does anyone know of a solvent that will clean this
gunk and some rust from tank?
John
11-27-1998 16:05:55
 Re: gas tank cleaning in reply to Ron Kinton, 11-26-1998 22:30:16
: I have several tanks from tractors and engines with "varnish"
: in the tank, and a Farmall H that is real bad and it has a baffle
: which makes it impossible to clean mechanicaly. : Does anyone know of a solvent that will clean this
: gunk and some rust from tank?
I have seen radiator shops that will clean and then seal tanks that leak. Perhaps they will just clean it for you.
Mike
11-27-1998 14:47:29
I don't know if this works but I was told to put 1/2 a can of draino and about a gallon of water . Then take 5 or 6 rocks or bolts put all in tank . Then shake the tank and flush real good.
