Tool Talk Discussion Forum
Wayne aircompressor
haynes57
12-25-2005 12:43:22
Hi,
I just acquired a 1967 two stage Wayne Air Compressor with a 16 inch pulley on the pump. This came from a Service Station where they had a line leak and thought they needed a new compressor. They had removed the original 5 hp motor. I would like to know how many rpm's this pump should turn. I have a new 1750 rpm Baldor 5 hp motor to use on it.Thanks in advance for any help you may give!
danny
Keith-OR
12-27-2005 19:48:14
 Re: Wayne aircompressor in reply to haynes57, 12-25-2005 12:43:22
I run my two stage compressor at 850 rpms. To calculate size of motor pulley when you know Motor RPM's and pump pulley size use the following.
Known (motor rpm's = 1725 RPM's)
pump pulley size = 16 inches
Let X = motor pulley size (if you plan on running at 850 RPM's, this value can be changed to what ever RPM's you decide to run your pump at)
..... . 850rpm x 16in (pump pulley)
X = ----- ----- ----- ----- ----- = 7.88 in. dia ..... . (Motor speed) 1725rpm
Motor pulley size to run pump at 850 rpm's would be 7.88 in. or 7 7/8" inches in dia....hth
Keith
haynes57
12-26-2005 17:06:54
Thanks to all for your comments and speedy replies. These were all good advice which I greatly appreciate. I will post again to let you know what I do.
Thanks so much!
dh
DH in Carloina
12-26-2005 06:25:40
Hello I have two Wayne two stage compressors both made in the late 60S. The flywheel pulley on each is 17 inches and the motor pulley is 8 inches in diameter. Both have 5 horsepower motors 1750 rpm, two groove pulleys with "A" belts. Hope this helps. Need a set of valves for one if anyone knows where to find them. DH
Charles (in GA)
12-25-2005 14:51:45
Wanna get reasonably accurate with it, go find some other 5 horse two stages that are compareable and measure the motor and pump pulleys, do your math and see what you get.
I think on 5 horse two stage, the vast majority of the pumps are run at 700 to 800 RPM.
Charles
Jay87T
12-25-2005 13:17:42
anything under 1000 rpm is good, I would run it at 700-800 rpm, these old pumps are not ment to spin fast. I have 2 Old pumps and I run them at about 750rpm. Keeps up good. I believe my pully size on the electric motor is about 4.25, If you need me to double check I can.
Jay.
