Tool Talk Discussion Forum
Paint oxidation on pickup
FarmerFred
12-23-2005 20:07:19
I have a nice '82 Ford that has bad oxidation. Have tried everything(cleaners, wax, rubbing compounds. I have a osolating polisher and a high speed bonette type. The white oxidation just keeps appearing. The blue paint is now blue and hazy white. Any ideas other than a paint job?
Keith-OR
12-24-2005 20:10:35
 Re: Paint oxidation on pickup in reply to FarmerFred, 12-23-2005 20:07:19
You don't want a high speed buffer, want one that turns less than 1800 rpm's. Mine is less than 1200 RPM's. Go to your local auto paint supply store, get some wax remover and some good Glaze not wax. After you remove all the wax then use your buffer to apply the glaze then apply a good sealer. The worst colors for oxidizing is reds of any shade, this is what I do on all red paints...HTH
Keith
Truck
12-24-2005 06:33:33
If that is the original paint job I'm surprised you haven't worn right thru it yet. Polishing, etc is the only way I know of to bring back the shine, but it takes off a little paint every time.
Are you sure some of the white spots aren't built up wax and polishes? I'd start by wiping the truck down with wax and grease rewmover, then use the non orbital buffer with some fairly agressive compound, then work my way up thru finer grits and finish up with the orbital and wax. I assume you know how to use the high speed buffer without burning the paint. If you haven't got that down yet, and I know no way to teach someone how over the net, go ahead and use the orbital. It will just take longer.
Up here anyone who buffs out an 82 pickup better have his tetanus shots...Assuming you can even find one to polish.
Once you get the paint to shine, the oxidation processs will start over. I have used clearcoat on such a paint job to preserve it but eventually it will look even worse when the clear starts to come off. If you use an adhesion promoter between the old paint and the clear it might work. A new paint job is the only sure bet.
Butch(OH)
12-24-2005 18:19:58
 Re: Paint oxidation on pickup in reply to Truck, 12-24-2005 06:33:33
LOL,, I had to read it four times to get it but good one!
