Tool Talk Discussion Forum
Small Parts Washer
J. Schwiebert
12-22-2005 13:21:25
Just put a new sink in the kitchen and was thinking about using the old one for a parts washer for the small stuff. One side for getting the real dirty stuff off and the other side for a rinse tank. We had a small homemade parts washer when I worked for the Oliver dealer using an old engine oil pump to circulate the fluid. Worked good. Thinking of doing the same here. Any suggestions>
Adam2
12-23-2005 00:09:10
 Re: Small Parts Washer in reply to J. Schwiebert, 12-22-2005 13:21:25
I just read an interesting post, on another board, that described an interesting setup for an ultra-sonic like device.
You take one of those vibrating foot bath tubs, put a smaller container, with the parts and cleaning fluid, taped down, and let the vibrating action of the foot bath work on the stubborn grime in tight places.
I restore a lot of old tools and rebuild ratchets.
I'm looking for a used foot bath in a GoodWill store. New ones cost around forty bucks!
bradk
12-22-2005 16:12:14
Hi John;I think you would be better off with a 20 gal parts washer from Northern tool.Comes w/pump,drain,and most importantly a lid.The lids also have a pin which melts at a certain temp slamming door shut in case of fire.$75.00-not bad!I've seen these mounted on bench-tops so only thing on the surface is the lid.Oh...kerosene works better than that crap sold as parts washer solovent.~brad
thejdman01
12-22-2005 14:39:58
that would work but new parts washing solvent has alot to be desired. nothing liek the good old stuff but"toxic" new stuff doesnt work well
Jay (ND)
12-22-2005 13:57:19
My neighbor does that with a double sink - for a pump he uses a dishwasher pump and motor. Has been on the same pump & motor for 10 years or so. He recirculates it through a furnace fuel oil filter - General Model #1A-25A - cheap refills for a few bucks.
