Tool Talk Discussion Forum
Stuck Freeze Plug
pbutler
12-21-2005 13:50:36
I am trying to remove a freeze plug in a Massey Ferguson 255 Diesel tractor to put in a block heater. The plug is about a 5/8 hex bolt so I get a good grip in it with a Hex socket but can't budge it.
Since it is right in the block I am a little scared to put an impact on it and with 20 degree weather the using the torch to heat/cool seems really dangerous. Sprayed with PB Blaster but almost no threads exposed so I doubt if much at all got anywhere valuable.
Anyone have any other suggestions?
Aaron Ford
12-24-2005 19:17:31
 Re: Stuck Freeze Plug in reply to pbutler, 12-21-2005 13:50:36
I heat and quench with wd-40. Crude, even stinky but it works.
Mike M
12-22-2005 06:47:59
I think I'd try an impact before heating. An impact can really jar stuff loose you can't budge by hand.
Bill from wisc
12-21-2005 15:33:08
A trick I found that has always worked for me since is to drain the block. Heat the plug red hot and then put some Beeswax( not candle wax but true Beeswax) on the plug. As the plug cools it sucks the wax into the threads and will turn right out once its cool. Good luck
Dog's Friend
12-22-2005 06:03:29
 Re: Stuck Freeze Plug in reply to Bill from wisc, 12-21-2005 15:33:08
I've heard of the bees wax trick. But where do you buy bees wax?
Thanks
Chester
12-23-2005 07:53:43
 Re: Stuck Freeze Plug in reply to Dog's Friend, 12-22-2005 06:03:29
I"ve heard of the bees wax trick. But where do you buy bees wax?
Toilet seal rings.
sjh
12-22-2005 19:08:57
Craft stores.
Bill WI
12-22-2005 11:14:04
I've always used plain paraffin and it worked for me. Even rub it in the snowblower chute ( with it SHUTOFF) You can find it with canning supplies. Looks like a 1 lb butter carton and has 4 chunks.
Bob
12-21-2005 13:57:33
Drain the block, heat the plug red hot, and allow it to cool to ambient before trying to remove it.
It is not unusual to have to resort to that method. Just try to use a flame of reasonable size, and heat the plug directly, and not the surrounding cast iron.
JD9295
12-21-2005 13:55:29
Run the tractor and let it warm up the block, keep pb blasting it and peen around it to help knock the threads loose
