Tool Talk Discussion Forum
barn/shop doors
vrickster
12-20-2005 14:09:10
I have a 16' wide by 12' high opening on each end of my 40' wide bldg. I am now at the stage of figuring out what kind of doors to put in. This is what I have figured so far:
roll up garage type doors- toooo expensive and loss of head room
sliders- ??
vertical bifold- snow on ground is NOT a problem for me being in south texas. easier to move than slider
horizontal bifold (aircraft hanger like) expensive- requires heavy reinforcement of rafters.
What is your experience with your doors? Recommendations?
msb
12-21-2005 20:35:22
 Re: barn/shop doors in reply to vrickster, 12-20-2005 14:09:10
To build a really good sliding door use the National Hardware Quick Frame end rails.They make a very nice strong door using ordinary lumber and steel roofing.I use treated 2x6s on the bottom member and 2x6 cross members. Use roofing screws to fasten the all together.When finished, they look like factory made doors and are very strong.
vrickster
12-22-2005 14:17:36
 Re: barn/shop doors in reply to msb, 12-21-2005 20:35:22
can you tell me more about these quick frames. I tried to find them on the internet with no luck.
PatMz
12-23-2005 06:52:56
 Re: barn/shop doors in reply to vrickster, 12-22-2005 14:17:36
Here's link to "Kwik Frame", manufactured by Cannonball. Click on Kik Frame under Sliding Door Systems. It'll open up an Adobe PDF catalog.
MarkB_MI
12-20-2005 18:29:46
An overhead (garage style) door is hard to beat for a good seal. Yes, you will lose about 2 feet of door height versus a slider or bifold. That is, unless you have trusses that will allow you extra headroom.
Charles (in GA)
12-20-2005 17:12:17
Here you go.
Link
farmall404
12-20-2005 15:46:34
I built two 6' x 12' doors for my 12'x 12' opening out of 2" angle, insulated garage door blanks, and 2" flat bar holding it in. 2" flat bar xing across the front for sag prevention, 4" angle frame work to hang the doors on, 6 heavy duty house door hinges welded on each door; been up for 12 years, no problems. Cost was about $300 dollars vs $1200 to $1400 dollars for a roll up door.
Jim in N M
12-20-2005 15:26:57
You might look into a "low overhead clearance" overhead door. I believe you only need about 12 to 14"of clear space above the opening! I had the same problem.hope this helps. Jim in N M
old
12-20-2005 14:55:02
My self I like over head or slideing doors. I've found the bi fold are problems because over time they sag and if its windy you can end up takeing a trip you don't want to take.
