Tool Talk Discussion Forum
Snow Fence
dab
12-19-2005 09:15:35
Got a question that is off topic but does anyone know a good way to get this $#*^& plastic snow fence to stay up without ripping. I only had two sections of the wood stuff and needed more so I bought some of that plastic stuff and it keeps ripping at the poles.
JD9295
12-20-2005 09:40:49
 Re: Snow Fence in reply to dab, 12-19-2005 09:15:35
we run a small 3/16 cable the lenght of the run drawn tight then use cable ties, alot of them, and it holds good. trick is to get it as tight as possible, if it can whip at all, it will rip
duey
12-19-2005 17:41:12
We put up a couple hundred feet every year, we trap the mesh against the post with a lath, but also weave a heavy wire along the top of the fence and draw it good and tight. (The wire is helpful setting the posts sort of in line!!) We have never had it break and the mesh is at least 5 years old. We connect roll-to-roll weaving a lath through.
Eastern MN, so there isn't wind like say No. Dakota.. but it is still winter.
duey
riverbend
12-19-2005 11:34:54
The best luck I ever had with the plastic junk was to trap the fence between a lath and the fence post. Even at that, the wind will eventually cut it off against the fence post.
Ralph - Ohio
12-19-2005 10:56:51
I have not used the stuff but someone earlier said it's important to keep the fence on the side of the posts toward the wind so the wind blows the fence against the posts. This helps to keep it from tearing where it's tied.
caseyc
12-19-2005 10:34:33
i fought the same problem and couldn't make it work so now i just use round bales, works great!
casey in SD
