There are some chargers on the market that say they have float charger ability in them. But if they don't tell you specifically what the float voltage is then they probably are not true float chargers. Some just turn the charger off when the voltage gets to a certain point and turn it back on again when it drops to some lower value. While that is probably better than leaving it on all the time it is not a true float charger and could damage the battery if left connected over a long period of time. A true float charger puts out 13.3 to 13.6 volts constantly. A better one will adjust itself slightly for temperature variations within that range. A 12 volt battery will last almost indefinitely when connected to the proper float voltage. It will maintain its charge and will not be overcharged. The battery should first be properly charged before leaving it on a float charger as most float chargers don't have enough capability to properly fully charge a battery if it is low. Also to properly charge a battery the charge voltage needs to be up around 14 to 14.7 volts depending on the particular type of battery. But once it is charged it should be "floated" at the 13.3 to 13.6 volts. The float voltage is critical. Some older chargers, particularly marine type chargers were regulated at 13.8 volts as a compromise between charging and floating the battery. Those chargers will not properly fully charge a battery and they will also cook the battery over time because 13.8 volts is too high for a float voltage. Float current is pretty low for a fully charged battery. It is usually around 100 MA or so. Just enough to overcome the self discharge rate of the battery. So a small float charger is adequate for most batteries. You don't want to leave a 2 amp charger connected for too long a period. It will cook the battery. A trickle charger will also cook a battery if left on for long periods. Look at it this way: If the charger has enough output to fully charge a battery, even if it takes a few days to do so, then it has too much output to leave on for long periods of time. As far as charging a battery goes, the best type charger is a multiple stage type where a bulk stage limits the current to say around 25 amps. It pumps as much current in up to the 25 amp limit until the voltage reaches a certain point. Then it switches to a voltage limit and the charge current tapers off as the battery approaches the voltage limit that the charger is set at. This is a rather long slow process to top off the battery charge. Some gassing of the battery should take place during this stage to properly finish the charge. Then it will switch to the float mode at the lower voltage of 13.3 or so to maintain the battery there. Regards Gary
