Tool Talk Discussion Forum
Compressor Regulator
S/C Bob
12-18-2005 03:42:28
I bought an air compressor it`s an 80 gal. tk. 5 hp.It didn`t have a regulator on it so when I got it up and running I put a 3/8 regulator on it.The problem i`m having is I can set it on 80lbs.But when I start my tools the pressure on the regulator drops to about 40lbs.and is too weak for the tool.Now the tk. has plenty of pressure 120 or better.Any ideas. Thanks in advance....Bobby P.S I`m using 1/4in hose on it.
JD9295
12-18-2005 05:43:32
 Re: Compressor Regulator in reply to S/C Bob, 12-18-2005 03:42:28
Hook up an air tool and adjust the regulator while it is running (the tool). You need to raise your operating pressure.
Might have to go to a bigger regulator and air line if that wont fix it
