Tool Talk Discussion Forum
Smith Torch nut dimensions?
Stickler
12-17-2005 12:28:26
I want to modify a circle cutting attachment the wife gave me for Xmas to fit my Smith torch. I have the Smith SC205 cutting attachment. What I'm after are the inside dimensions of the nut that holds the cutting tip on. I'd measure my own, but it's 450 miles away at home and I'm at work where I have access to the machine shop. I need the thread size and depth, and any other inside dimensions. Isn't there an indent where the flange on the tip fits into?
Thanks,
Stick
Stickler
12-19-2005 18:37:34
 Re: Smith Torch nut dimensions? in reply to Stickler, 12-17-2005 12:28:26
Thanks Fred! Much appreciated!
Fred OH
12-19-2005 13:57:20
When I read the rest of your post you asked for the thread dimensions too...so...here is page two:
The external threads (.992") is actually 1" X 20 threads per inch. the formula for external threads is as follows: Slant depth = .750 over number of thds. per inch or .0375"..this is the amount you feed in after touching the threading tool on the OD with the compound set at 30 degrees swung to the right as you"re looking at it.
Now, on the internal threads...you have to swing the compound to the left 30 degrees and the formula for that is .649519 over number of threads per inch or .0324" that you feed the internal single point threading tool in. Good advise would be to go 3 or 4 thousandths deeper if you don"t have a part to test fit it with.
The bore size is major diameter minus 1.0825 over number of threads per inch or .946" dia. to bore it to before threading it. Clear as mud??? Just print this and give this to a good machinist and tell him you"ll buy his lunch and watch what happens. Fred OH
Fred OH
12-19-2005 13:31:44
Stickler...here is the dimensions on my Smith combination torch SC 209 QK:
OD of threads = .992"
thds per inch = 20
nut total length = .715"
hole for tip = .610" dia.
back of nut to flange = (slight taper on face) .554" length next to .610" hole
across flats of nut = 1 1/8"
inside dia. of threads = .943"
1 1/8" hex is only about .200" long, the rest is knurled.
external thds. in middle of torch = .862" OD
TPI of same = 14 TPI
Looks like theres a slight chamfer/bevel on the flange back inside that probably just aligns the tip on center.I"d guess about 15 degs.
I think I got them right...I bout froze my fingers measuring these...I"m stayin in the house till it warms up. Fred OH
