Tool Talk Discussion Forum
cutting oil
hay
12-16-2005 13:27:29
what exactly is "cutting oil"? i have been using some light weight motor oil with fairly good results, but a friend says cutting oil will protect drill bits and dies and taps better than motor oil. could motor oil mixed with kerosene or diesel do just as good? all my drilling is at low speeds (250-450 rpm) so i'm fairly sure the bits are not getting hot enough to 'blue'. i'm looking for some expert opinions here. thanx.
kidbob
12-18-2005 22:19:21
 Re: cutting oil in reply to hay, 12-16-2005 13:27:29
If you must use a home remedy instead of the real thing, use Lard (pig fat).
shannon from ohio
12-17-2005 16:32:24
LPS-Tapmatic cutting fluid
Lumpy
12-17-2005 16:19:59
Try Tap Magic-- you'll never go back. This is going to sound crazy but, I use 97% rubbing alcohol or methanol for alum. Been a machinist for 17 years, the alcohol/ methanol is unbelievable.
TomTX
12-17-2005 13:53:11
Best stuff I have come across is Brownell's Dew-Drill (probably mispelled). Drill bits last about 4 or 5 times longer and cut like a dream.
BobHnwOh
12-17-2005 12:45:28
I use 10W30 Mobil 1,it works great!!Bob.
M.Johnson
12-17-2005 10:24:55
I like to use BOELUBE paste. The ORElube Corporation New York 631-205-9700 Made in the U.S.A.
jerrycpp
12-17-2005 05:56:24
Go to a welding supply shop and buy some TapMagic or whatever equivelent they have. You'll think you broke your tap or your drill bit it'll cut so fast. The stuff is as thin as water. This is what many industrial places use - it saves taps and bits, and speeds up the whole operation.
Jon Bohlander
12-17-2005 05:41:19
I would recomend pipe threading oil from the hardware store as a inexpensive, readily available cutting oil. Apply it with an acid brush, it doesn't take much so a quart will last a long time. You'll see a big difference when tapping in ease of tapping and thread finish. As far as drilling , besides cooling a good cutting oil will help the chips slide up the flutes. Good chip evuacation will help your finishs as well keep the heat down when drilling, milling, etc.
For aluminium, WD-40 works well also. It really helps with chips welding to the tool and finishes. I'd still use a cutting oil for tapping.
I work as a machinist so I have gotten a chance to try alot of different fancy cutting oils. For the most part you don't really notice a big difference (except tapping). So dark pipe threading oil is what I use in the home shop. Motor oil will work in a bind but the few dollars spent on a real cutting oil are worth it.
Jon
timcasbolt
12-16-2005 14:03:11
cutting oil usually has sulfer or clorinated parrafin in it to promote better cutting. it provides more benefits in a production environment than when cutting one or two holes. in a home work shop you could mix bar and chain oil with a little kerosene to cool the tools. motor oil has too much other junk in it you don't need. for tapping, you might want to try crisco.
john,PA
12-17-2005 04:02:09
 Re: cutting oil in reply to timcasbolt, 12-16-2005 14:03:11
I always use kerosene fer aluminum tapp'n.
WATER makes fer a good one fer drill'n holes in old CUT GLASS BOWLS when I wants to make a lamp shade. Only use for the bowls that mom had in the china closet.
John,PA Happy Holidays :})
PS: error
12-17-2005 04:03:09
 Re: cutting oil in reply to john,PA, 12-17-2005 04:02:09
I meant to say I use TURPENTINE for al.
chvet73
12-17-2005 10:55:52
 Re: cutting oil in reply to PS: error, 12-17-2005 04:03:09
My Home Depot carries cutting oil. They hide it with the Wd-40 and good old 3-1 oil. Works great on steel. Use the WD on AL.
