Tool Talk Discussion Forum
Belts on blower
Buzz
12-15-2005 14:53:12
Got an old snow thrower here. Needs belts and I'm not sure what length. Any handy tricks in measuring/guessing on what length of v-belt to put on?
It's a Lambert Model HS 541
Thanks,
Buzz
jeffcat
12-16-2005 09:28:52
 Re: Belts on blower in reply to Buzz, 12-15-2005 14:53:12
This is just a little on the simple side. If you can just load it up and take it to town. They can fit you up a LOT quicker. Jeffcat
Bob
12-15-2005 15:15:29
I assume the old belts are missing, so you can't take them along for the "bearings and drives" place to measure?
If you can find an old belt of the correct width, but a little longer, what I have done is to trim a section out of the old, longer, belt until it is the correct length, and then taken that to the belt place to have them match a new belt to it.
That will get you within at least one size of the correct belt.
Bob
12-15-2005 15:14:32
I assume the old belts are missing, so you can't take them along for the "bearigs and drives" place to measure?
If you can fin and old belt of the correct width, but a little longer, what I have done is to trim a section out of the old, longer, belt until it is the correct length, and then taken that to the belt place to have them match a new belt to it.
